Question about Coleman Heating & Cooling
29 year old Coleman Gas H/A will not shut off... Installed new CT-30 Honeywell 2 wire Thermostat single temp control. The unit works but will not shut off unless I pull fuses & shut off Braker
  • 3 more comments
  • ebysan Aug 21, 2008
    I wired the White wire to the W & the Red wire to the R. A Technician at Honeywell said there is no polarity so it did not make a difference where the wires went. I called because I had purchased another honeywell with a shut off. The Technician said I had the wrong Thermostat...I needed a simple 2 wire unit. I went to 6 stores before I could find a CT-30 unit...Thanks!
    I am having a home Safety Inspection on the mobile tomorrow morning to allow me to sell the Mobile Home.  A few weeks ago it was 104 degrees out side ..I had the temp set on 55 with heat lever depressed. The heat came on & would not shut off...We have been doing a lot of repairs to the home including sanding the kitchen floor that as adjacent to closet of heating unit. My husband bought me a Hunter thermostat...I called the Technician before installing because i only had 2 wire coming through the wall..She told me there was a jumper installed & i could install this but it ha a cool cycle & a heat cycle plus an off ...The unit would work on heat or cold but would not shut off
    I did not take the front off of the unit in closet...I did not see inner stat...could ther be dirt on inner stat causing the problem?
  • Gary Davd
    Gary Davd May 11, 2010
    one other ting if this ia a furnace (gas) and has an A/C with it you cant use a 2 wire stat
    Same is true if it is a pkg unit
  • Gary Davd
    Well maybe you can look at this and it will help you
    R=Red wire Hot 24V
    W=White wire usally goes to the heating side or W1
    G=Green wire this controls the fan realy (blower inside)
    C=Common wire can be any color mostly black test here and red to get 24v
    O=Orange wire only used in heat pump systems for rev. valve
    RC=Red terminal for cooling
    RH=Red treminal for heating
    Y=Yellow feeds power to turn on the outside unit (at Contactor)
    Hope this helps
  • Gary Davd
    can you post the wiring you did
    Problem Solver:
  • 9 Answers
All coleman gas units is incoperated with a secondary inner stat. It resembles a pie with numbers on its outer edge. Usually silver and the numbers span from 50 to 300 on the top and likewise on the bottom. You must not turn it clockwise. Refer to specifications of manufacture to allow proper function.
Posted on Aug 21, 2008
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Connect one to Red, R or Rh.
Connect the other to White or W.
Jan 09, 2009 | Honeywell Programmable Thermostat Heater
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Coleman gas H/A not shutting off
Yes and No. Sawdust even when in get in internal parts will not cause the problems that you are experiencing. More than likely your sencondary thermostatic control for the condensor is not set at proper settings to work proficiently with external thermostat.
Aug 21, 2008 | Heating & Cooling
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
53 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
