Question about HP D8597A Keyboard
HP Keyboard letter F is coming loose - how to remove and reattach
  • 25 Answers
Adere some super glue to the outter circle of the F key underneath and push it back into the silicon. make sure you don't keep the key pressed down while the glue dry.
Posted on Aug 21, 2008
Letters dont come up as typed
If something different than what you typed comes up, then it is probably the keyboard settings that are to blame, if nothing at all comes up then it could be a loose connection between the keyboard connection to the motherboard.
Mar 21, 2011 | Acer Aspire 5520-5908 Notebook
I need to replace the letter J as it has come loose from the keyboard . Is this possible ?
The letters are attached to the keyboard with the clips. Check if the clip is broken or not . if not then contact the manufacturers spare parts department and get the part and attach it.
Mar 15, 2011 | Compaq Keyboard
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
HP MINI keyboard letters doesn't want to work
the letters of n, b and six, seven of my HP Mini 110 keyboard would not work, what should i do?
Oct 28, 2010 | HP D8597A Keyboard
Keyboard doesn't work when i press certain letters
your keyboard connection might be loose, try disconnecting your keyboard and reconnecting again
Jan 14, 2010 | HP Mini 1000 Netbook
My T popped off key cap and I need instrutions to put it back on.
It just snaps right in. just make sure it's right in the middle and snap it in. If it doesn't work, make sure it's being aligned correctly, but like I said, it should snap back in.
Nov 21, 2009 | HP D8597A Keyboard
My keyboard has stopped typing
Remove the keyboard: HP.com /service manual then reattach/reinsert the "tape" cable from the keyboard to the motherboard
Aug 24, 2009 | HP Compaq Presario F730US Notebook
Tab key hanging loosely unable to use
I take it that the TAB key has come loose from the keyboard. Usually when the keys come off a laptop keyboard, they can be clipped back into place. However, the keys usually have a scissor like support on the underside of the key, which have small plastic pins that need to be latched onto the keyboard itself.
To be honest they are a pain to reattach, so if you have the patience and a steady hand, give it a go, otherwise I would get a repair tech/engineer to look at it. It may be that the key is damaged, in which case you will more than likely need to replace the keyboard, as key caps don't usually get sold separately.
Jun 01, 2009 | HP Pavilion ze2000 Notebook
Typing Problems
This problem happens in all notebook of quite some age of 3-4 years.. The keyboard is enbedded to a single board unlike the other desktop keyboard.. I had this problem once in my Dell lappy..I removed the case, ffound the ribbon wire of the keyboard whichc connects to the main board, removed it and reinsterted again, anad the problem disappeared...better give it a try..
Mar 30, 2009 | HP Pavilion dv2700z Notebook
My laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Mar 18, 2009 | HP Hewlett Packard Pavilion DV9000Z 17"...
HP D8597A Keyboard Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
