Question about Sharp AM-400 Digital Multifunction Printer
SMUDGE LINES WHEN PRINTING MY DOCUMENTS DOWN BOTH SIDES ARE UGLY SMUDGY BLACK LINES. HOW CAN I GET RID OF THESE, FOR A COMPANY THEY LOOK SO UNSIGHTLY ON MY ACCOUNTS!!!
  • 25 Answers
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Posted on Aug 21, 2008
Not fully printing any document
Print a test page and perform head clean if necessary.
Oct 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My printer keeps printing black smudge like lines on the sides of the paper. Can you tell me what this might be?
usually its a defective toner cart. recycled carts are just refilled, they are not reconditioned. I would remove that cart, clean the mechanism, and replace with a new cart.
Jul 21, 2009 | HP LaserJet 4 plus Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
May 29, 2009 | HP LaserJet 3330MFP All-In-One Printer
Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Mar 30, 2009 | Konica Minolta bizhub C450P Laser Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Smudgy printing with dark grainy areas,
Hi miss yan;
According as your descript the first impression coming from my mind is drum unit problem, the parts you need to replace is drum, cleaning blade, my suggestion replace developer too.
Let me know ,if you need more help.
THANK YOU , HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Office Equipment & Supplies
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Printer running too slow
This worked for me, open the lid of the printer, there is a "white band" attached to the 2 printer cartridges, this was "smudgy" with ink, got kitchen paper and cleaned it and used q tips (I normally clean my ears with them) and got rid of the sludge and dust located on the floor underneath the printer cartridges. After that printer is working fine, hope this helps!
Oct 30, 2006 | HP DeskJet 1220c InkJet Printer
197 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
