Question about Dryers
Dryer wont run I have checked voltage all switches seem to be ok. it is an older kenmore dryer #76873400 it just stopped running , no warning does it have a fuse in circuit thar may be blown ?
  • 770 Answers
Yes there is a thermal fuse on the exh duct it is white jumper it and see if it works
Posted on Aug 21, 2008
My dryer quit heating and I replaced thermal fuse. It heats now, but when the door is opened it does not stop running. The switch seems to be OK. Have any suggestions? It did not do this before fuse...
Hello Rohanna
You need to check this following:
Make sure the dryer is plugged in securely
Check for a blown fuse or tripped circuit breaker
Test the power outlet for voltage
Inspect the electrical cord for damage
Eliminate use of an extension cord, if any is being used
Check the outlet voltage
Test the door switch
Test the start switch
Test the safety fuse
Test the thermostats
Test the timer motor
Test the motor
Best Regards
Neciforo Llanto
Oct 01, 2013 | Kenmore Dryers
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
I think my dryer finally stoped
Inspect the start switch and the door pressure switch as well. if both switches check out OK, replace the timer/control device.
Jun 03, 2009 | Kenmore 700 6972 Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont run any ideas?
It has got to be the door switch. The fuse won't stop this appliance from running.
Mar 03, 2009 | Kenmore 72982 Gas Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
