Question about Dometic Rooftop RV Air Conditioner
Compressor tries to start but want
Duo-Therm- Dometic roof unit. The fan runs fine but when you click thermostat to engage the compressor it tries to start or surges and within 3 seconds it clicks off. Have tried replacing the two capacitors with no difference. Any idea why the compressor want start up.
  • 3 more comments
  • buttercat52 Aug 21, 2008
    It can't be that simple but you can bet we will try tommorrow. Thanks
  • buttercat52 Aug 22, 2008
    try connecting directly and when I flip the switch to engage the compressor it immediately flips the breaker. Do you think it is either of the two capicitors or does compressors short out. I'm lost tried installing the two new capcitors but was still using a extension cord. Return the capcitors back to company I ordered before I tried connecting directly to power source like a idiot.
  • nellybell12 Jan 15, 2009
    the fan runs fine the compress comes on but then shutes off.
  • Mike Butler
    Mike Butler May 11, 2010
    Has the actual voltage to the AC unit been checked ? If it's posted somewhere I missed it sorry.
  • Anonymous Mar 28, 2014
    Fan not starting by itself Will run when helpt along by hand
  • 417 Answers
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Posted on Aug 21, 2008
  • Jude Meredith
    Jude Meredith Aug 22, 2008
    hi,
    how many amps is that breaker thats tripping? it has to be 25 or 30 amps or it will trip. hook the old wiring and capacitors up the way it was and hook it to a higher amperage breaker circuit in the house. also look closely for a decal which shows the voltage for the unit, it may be that the air conditioner is 220 volts, but most likely the compressor is shot, if they sit for a long time they freeze up and wont run. mabe take the air conditioner off and call some used appliance stores and maybe take it to them for a repair. your not an idiot, the only way to learn is from your mistakes.
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Apr 13, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
454 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
