Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Ya...Ok big Irish, Yes, of course that is fine if you research this for me!! Wow, I really appreciate your time on this problem. The situation is this: TV unplugged...all quiet... Plug it in and even without touching the remote, or the power switch, the bulb and both fans come on. A very brief flicker on the screen takes place. Normal boot up sequence of the front panel LEDs take place. On the Power P.W.B. board, all LEDs do light up as they should. Bulb and both fans will stay on for approx 3-5 seconds. Then after the 3-5 seconds, the bulb and both fans turn off. When this shutdown occurs, the TEMP LED on front panel blinks. This is the only LED on front panel with activity. On the Power P.W.B. board, the green LED @ D913 will stay on, but the rest of the LEDs turn off. If you attempt to turn on the TV with either the power switch or the remote, the same things will happen. If you unplug the TV, and reconnect it to an outlet, the same things happens all over again. The bulb was just replaced about 1 month ago (OEM, not junk). When this problem surfaced, I attempted to fix, but have gotten nowhere. I understood the front panel TEMP LED to indicate bad fan(s). I then replaced both fans (yes...both). Same exact problem as above with new fans. Then I replaced Power P.W.B. board. Same exact problem as above, nothing has changed. Again, thank you for your time on this. egear00
  • 927 Answers
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Posted on Aug 26, 2008
SOURCE:
How to remove the 2007 chey impala heater core
!! WOW !! WOW !! Is It LEAKIN ? Wait Big Job You Are Lookin At Here why do you want to change it if it,s Leakin yes Ok But then go to warm Place to do it and Be ready to spend Lot,s Of time Doin it And replacing the A/c Freezing in it too it,s not fun to do look at the controls maybe the swich is not workin maybe the fluid is weak Maybe the thermostat is not workin I,m Wondering Why You what to do this Get it checked First to see what It IS Lot,s Of Money to do this When Just MAybe It,s Something Small In Stead Let ME Know What HAppen,s Cause I,m Mechanic for 35 years and I,ve Never seen them done It,s Not Normal Something Else Is The Problem Here So Please Let ME Know What You Do So Might BE Able To Save YA Some Money Thank,s Again for your Time. Farmer Is My Name Car,s are My Game to fix Is the Game not To Be Mean to My Customer,s is my Aim thks again
Mar 04, 2015 | 2007 Chevrolet Impala
I just bought a used Excell VR2522. The guy I bought it from said that it worked great (of course). I did have him demonstrate it to me and it seemed to work fine. The motor started right up and the...
yes you have a bab pump if you want i can get ya one cheper than what most pepole can shoot me a e mail with your phone number and ill callya and price ya one tthanks mickey
Aug 30, 2010 | Garden
I uninstalled creatures3 folders, witch had the uninstaller file
Relax man...
Go "Here"...
http://www.ursoftware.com/
Download and install "Your Uninstaller"...its a great program I've used for a long time. It will get rid of the problem for you and if you have to you can use the "brute force" method and clean up any remaining traces with it as well. There's a free trial period, so if you wanna buy it you certainly can, or simply uninstall it afterwards.
Good Luck
Jul 25, 2009 | ASUS P4S800-MX Motherboard
My toshiba wont start it keep's restarting at the black loading screen.
have you done a maintainance on it to get rid of all the excess information?? if not..go to start--then all programs, then accessories, then tools, click on disk cleanup. click on yes to all when the pop up box show up.
after this do a defragmentation-- go to start, all programs, then accessories, then tools, then disk defragmenter. click on analisys-- this will tell you if you need to defrag your system. if yes-- do it..it will take time to defrag, but it will speed up you game play ability.
Oct 13, 2008 | Toshiba Satellite P305D-S8828 Notebook PC
Got it...
Good Day, egear00;
Let me do some research, this info was my head. Please recap what the problem is and what all the items you replaced. Okay?
big IRISH.
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
Getting close...thanks
egear00; OK, you have voltage, check this:
1. Filters make sure both are clean
2. Check the power supply and check for bad CAP's
3. Check the lamp sensor.
Good Luck, big IRISH.
Aug 19, 2008 | Hitachi 60V500 60" Rear Projection...
Great...Thanks
Good Day, egear00;
This chart shows were voltages are on the ballast. If you the voltages then suspect the ballast, if no voltage suspect the the power source.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Vs-45607
Good Day, chefkenny;
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Double color image (blue and Yellow)
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Jul 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Ya, sir
ok thats better ...
Since u r solo,,i would always recommend u to do small projects. coz big proj really take lot of time n need much for sopohistications...
when u do projects on ur own,only ur interests matters..can u mention sum of ur area of intersts like games software,application , banking etc etc?
tank u
Jul 09, 2008 | Microsoft Windows XP Professional
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
