Raymond Milford Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weak output on one channel when playing CD using the auxiliary input.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 18, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2765884
Points
24828
Swap the input cable channels to determine if it's the unnamed CD or the unnamed receiver. Try (or swap) other cables, inputs, sources, speakers.
Continue from there. Hint: name things if you want specific help. Look at manuals.
2answers
Kenwood KRV-6050. Is there a way to change headphone jack on it from output to an input so I can play my cellphone playlists over home speakers?
You can’t through the head phone jack but you can behind the receiver. In fact there are several ways you can play music from your phone to the stereo. Use the input for CD player, Tape 1 or 2, video player. Usually the Auxiliary would be used but you don’t have one. Almost all inputs will work except phono.
tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
1helpful
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
My Philips DCM230 home stereo system wont produce any sound. The CD is playing, the voulme is on, and the mute is off. What could be the problem?
Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
How do i play my ipod through the home theathre
Get you an Ipod harness adapter with RCA plugs from Radio Shack. Plug in the Left & Right channels of your RCA plugs to the Auxiliary input (or Tape, or CD inputs will work as well) of your receiver. Select that source input on your receiver and play your Ipod.
I have a Panasonic SA-PM31 stereo system with two auxiliary input methods: the first appears to be a common auxiliary cable input which says "phones." The second is a two cable input system...
The corect input for your ipod is another one who's name is "auxiliary" The "phones" input is dedicate only for pick-up, or another device who had to output a very small level signal. Your ipod have a high power level on output because he is amplified for a good level sound on your earphones. So, you can serious damage your Panasonic SA-PM31 sound system when input a too high level signal on "phones input" Phones is for unamplified audio signals like pickup signal direct from the head wires, or casette deck signal direct from the head wires. Gross (unprocessed) signal.
The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
No input selection for phonograph. can i not play a turn-table through this thing?
Hello sir hi, good day. Phonograph are becomming obselete these days, and most electronics manufacturers now omit the phono input.
You can use your phonograph but you may need to buy a separate phono preamp or audio mixer to be fed on any line in input such as auxiliary or CD in.
If I miss anything feel free to ask again, = )
Hooking up dvd player
Look for any button either on the unit or the remote marked with common stuff like A/V, Input, Source, Aux or Au, Line, TV-VID. or try dialing in Channel 0, or 00, or 1, or Channel Down surf below Channel 2. Alternately, get into the menu and look for stuff concerning Auxiliary inputs.
If all else fails, you can run a DVD's audio and video line-signals THROUGH a VCR. Hookup the VCR to the TV's RF (threaded) connector using standard coaxial cable. Hookup the DVD a/v output lines to the Line-ins of the VCR. Tune the TV to Ch. 3, tune the VCR to Line-in or Auxiliary and press the play or tv/vid button on the VCR to force the DVD signal through on channel 3 onto the TV.
2answers
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
 Grubhead
Grubhead
SmartAviator
SmartAviator
