Question about Honeywell Programmable Thermostat Heater
Stuck at 79 degrees
When my thermostat is turned off it still maintains a termperature of 79 degrees. When I turn it on to cool I can change the indoor temp from 79 but after 17 or 18 minutes it reverts back to 79. It won't even hold the scheduled indoor temp and always goes back to a setting of 79. I've reset the factory settings and still the same problem. Can you think of anything?
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
  • 22 Answers
SOURCE: cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Posted on Jan 02, 2009
  • 61 Answers
SOURCE: Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Posted on Jan 10, 2009
  • 137 Answers
SOURCE: Honeywell programmable Thermostat won't hold time or program
Most thermostats use a six volt transformer for a power source, similar to a door bell, you can tell if yours does by looking at the wires that are attached to the thermostat.
The wires will be thin with just a single strand if you have these wires then you have a transformer, try and find the transformer (good luck) test it with a voltmeter if it fails the test that's it, if not, call the man. Probably it though.
Posted on Feb 15, 2009
  • 3433 Answers
SOURCE: My thermostat will not change the temp when trying to change
Posted on Jun 10, 2009
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
I have a heat pump that when calls for cool it turns on, but when turned to heat,it does not turn on the compressor.
Check your thermostat setting above 79 degree and also mode" Heat " .Wait for 3 minutes. If still problem check power from thermostat to RV.
Dec 14, 2010 | Heating & Cooling
not sure how you system is set up but it almost sounds like you have a maintain system or a stuck thermostat to stop the heat if you dont make hot water with this boiler turn off the switch on boiler till you can get service person in if you can tell me more about the way your system is set up i could help more.if you want to see if its a problem with thermostat pull red wire from subbase
May 02, 2009 | Honeywell Electronic Programmable...
Friar heats up to correct temp but doesn't maintain
The first thing I would check is the hi limit.If that not out then I would try to a temp. gauge that will read above 350 degrees.maybe the thermostats is not right. Reading to low for the temp.
Mar 13, 2009 | Pitco Frialator 35CD Deep Fryer
After work I found my home heating system turning on every 5 min
You may have to reset your thermostat and reprogram it. First I'd check to make sure the batteries are good. Had the same problem. Hopefully you have the booklet that came with it. Bud
Jan 22, 2009 | ON-Q Home Hms Heat/Cool Thermostat...
I have 2 cental a/c units in my home. The 2 1/2 ton unit cooled great until abut a week ago. Now I cannot get it too cool lower than 78-79 degrees and it runs constantly unless I turn the themostat...
i like this one it challenging first do you know the refrigerant pressure?should be at least 65 psi for r-22 has any thing changed in the ducting? is the fan turning the correct direction?dan
Jul 14, 2008 | Heating & Cooling
Heating & Cooling Logo
113 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
