ERROR CODES; FAULTS & REMEDY
ERROR DISPLAY [IE] Inlet error. Condition: Not reached to the normal water level in spite of 10 min. water supply. Possible causes:
The Water Tap is not opened.
The Inlet Hose is twisted.
The Filter of inlet valve clogged by impure water.
The Inlet Water Valve is normal ?
The water pressure is very low. ( below 0.5 kgf/ )
Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
Open the Water Tap.
Repair the Inlet Hose.
1.Close the Water Tap. 2.Unscrew the Inlet Hose (Inlet Valve side) 3.Clean the Filter of Inlet Valve. > Replace or repair the Inlet Valve. > Check the water remain on the base. 1.Check the point of damages and repair or replace the related parts. 2.Disconnect the inlet hose to dishwasher to unlock the safety valve. ERROR DISPLAY [OE] Drain error. Condition: Not fully drained out in spite of 5 min. drain operation. Possible causes:
The Filter clogged.
The Drain Hose twistec or blocked.
The Drain Pump/Motor or circuit is troubled.
Remedy
Clean the Filter.
Remove the cause of twist or block.
Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ] Leakage error. Condition: The water level in Tub goes down during operation. Possible causes:
Water leakage in Hose connections.
Water is leaked by damages.
Impeller of the washing Pump is worn away.
The Thermal Protector of the washing motor is functioned
Remedy
Replace the connections of Hose.
Replace the washing pump.
Check the applied voltage.
ERROR DISPLAY [ F E ] Excess error. Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.). Possible causes:
support-us.samsung.com/.../pop_troubleshooting_fr... Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08 Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F... Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Error Code '1' indicates that the air intake filter needs to be removed and thoroughly cleaned. be sure to turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, could cause damage to the unit.
Hope this helped you and thanks for choosing FixYa.
Clean the air filter even if it looks clean. The air filter is located
in the front panel(unscrew knob to open door)...filter looked ok to me
but cleaned it under water and that fixed the problem. Note: I cleaned
the water filter first and that did not solve the problem. A simple test
to see if the air filter is the problem...take the panel door off,
press the filter door button and test hot water usage.
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test. Diagnostic Test Mode Procedure
Close the door.
Select the DRAIN/SPIN.
Select NO SPIN by pressing the SPIN SELECT button.
Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
"C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
