Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Reset the washer
Could you please tell me how to reset the washer, cause so far 2 people have told me to hold the back botton and the cycle botton for 3 seconds but i did that and nothing is happening, could you please tell me how to reset it.
yvonne
  • 1 more comment
  • Anonymous Aug 31, 2008
    I turn my dryer on and I get the message "A problem has been detected with the model connection selection". I try to reboot by pressing back and my cycles and I try unplugging the dryer for several minutes. Neither one fixes the problem. Any suggestions?
  • mistzyhayes1 Sep 13, 2008
    Krazytech,
    i tried what you told me to and still nothing, the screen will turn on and everything but it wont let me reset i hold down the bottons like you said but nothing,
  • dnhcaputo May 11, 2010
    Where do I find any replies to these posts, I'm having the same problems.......
  • 725 Answers
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Posted on Sep 13, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 14, 2008
    you may start by unplugging both washer and dryer. also check the connection (wire) that goes from the washer to the dryer...make sure you are at the HOME screen ...then press MY CYCLES and BACK .... hold for untill a screen comes up ...you my have to try a few time....if this will not work then the touch pad has failed you can remove cover and check the connection
SOURCE:
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
RCA P52937, Serial D045C504R. How do you reset the parental controls if you forgot the password?
i was told that the way to reset the code back is to simply hold the volume botton up, and the channel botton down for 5 seconds and it should read 0000. i hav'nt tried this , but thats what i was told.
Sep 23, 2009 | RCA P52937 52" Rear Projection Television
Whirlpool Duet stopped during wash cycle.
UNPLUG THE WASHER AND TAKE THE 3 SCREWS THAT ARE ON THE BACK OF THE WASHER OUT AND REMOVE THE TOP PANEL OF THE WASHER. CAREFULLY UNPLUG AND REPLUG IN THE WIRING SO THAT U WONT GET THEM MIXED UP. DO ALL OF THEM, FIRMLY BUT GENTLY. THEN HOLD IN THE SIGNAL CYLCE LITE FOR 3 SECONDS. TRY TO RUN A LOAD AND SEE IF THAT WORKS. IT DID FOR US, SO FAR SO GOOD. GOOD LUCK!!
May 30, 2009 | Whirlpool Washing Machines
Hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Jan 22, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
is any thing on or working check to make sure door is latched
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
947 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
