Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Ice Maker not working
I have the same problem that many others are describing with the kitchenaid icemaker. Light blinks sometimes, occassionally goes out and then after turning switch on and off several times it may come back on to the blinking mode. No ice getting made.
Thanks for your help
    Sergeant:
  • 409 Answers
check the inside of the door and incoming water line for any frost build-up.
if you don't have any build up, you may have a fault water valve.
Posted on Sep 17, 2008
Ice maker quit workingon kitchenaid side by side bowfront
check to make sure yr getting water to inside of ice maker if you are then replace the icemaker you can order them from marcone or allbrands appliance
May 16, 2010 | KitchenAid KSCS25FKSS Side by Side...
The ice maker is not working and red blinks on the
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
Dec 15, 2009 | Kitchen Ranges
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Overactive ice maker
You slide the that looks like a s into the ice maker head. then the other end goes in the other end hope it helps
Aug 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
124 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
