Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS2545SH coils freezing
Over the last 2 weeks the cooling coils in the fridge have been freezing. I keep defrosting the fridge with a hair dryer and it works for another 2-3 days. From reading a bit it seems that the fridge may need to defrost itself, but where is the control for it or how can I check if it's broken or just has a bad contact somewhere?
  • nhawk2 Aug 24, 2008
    I found a service guide for a similar Samsung fridge and it turns out that the electronic control of the whole fridge is located behind the fridge, and the voltage (120V) is being sent to the heating coil/fuse inside the fridge, but the coil is not working (resistance is infinite...coil is broken). Unfortunately, the defrost coil is physically together with the cooling coil and thus almost impossible to replace separately. In fact Samsung only sells it together as "ASSY EVAP-REF" part # DA96-00395C. Since Samsung has 5 year warranty on Evaporator (and this is part of it) I scheduled service to have the Evaporator replaced (I assume they'll have to cut the aluminum tubes and refill the fridge with R134a
    Problem Solver:
  • 5 Answers
Hey how's it going? I may have the info you need, but first I need you to go through a check list to see if there is a simple fix.
Check to see if there are any obstructions in the freezer drain (freezer drain located inside freezer compartment behind back panel lower right hand corner of the freezer coils) if there are obstructions or debris remove and clean with a mild dish washing detergent and water, check to see that water can drain freely. see if this helps.when the coils freeze is the ice flaky or is it frozen solid ice? if the ice is flaky it could mean that either the refridges/freezer door are left open to long "check your door gaskets or seals by closing the on a dollar bill if it pulls out easily with little to know resistance your door gaskets may need to be replaced. After you defrost the freezer coils did you notice if there was water in the condensor pan, if so good sign. (condensor pan: is the pan that collects the water that drips through the drain hole of the freezer compartment caused by the heating of the coil by the coil heater: water that enters the pan collects and is reused by the condensor fan by blowing warm air partly into the water and through the condensor coils causing them to cool.)if you still need to test your bi-metal therostat or your glass heater/ice pipe heater, you will need a multimeter and knowledge on the use of it.(IF YOU 'RE NOT NOT COMFORTABLE AROUND ELECTRONICS AND ELECTRICITY PLEASE CONTACT A QUALIFIED REPAIR SERVICE AND REMEMBER TO UNPLUG APPLIANCE BEFORE ATTEMPTING ANY REPAIRS) for more info on how to test please reply,Good Luck, be safe..
Posted on Aug 24, 2008
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Samsung fridge RS2545SH every 7 days freezes fridge coil.
no thermostat in this model but there are thermister it is also on the evaporator (yellow wire)
Aug 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Every 3 - 4 weeks i have to defrost my samsung side by side fridge freezer with a hair dryer as the cooling system keeps icing up
you have a defrost problem there are Three parts to it a Defrost control board a Defrost Heater and a Defrost bi-metal thermo-disc I would check the heater first it is in the coils you are defrosting
Jun 09, 2008 | Samsung Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side-by-side RS2545SH with several problems, possibly related
never buy a samsung appliance because you can not repair them. the company would like for you to buy a new one . my fridge the rs265labp freezes up in the fridge section and i have to take it apart once a month to defrost it. but i did find that if you keep a couple of boxes of baking soda in it and replace them often it helps to make the time between defrosting longer. hope this helps someone. i hope that samsung either goes out of business or straightens up
May 27, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2630SH Side by Side Refrigerator Logo
1,033 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
