Question about Philips HDD1630 MP3 Player
My cmputer is not picking up the gogear!!!
When i plug it into the computer the gogear says it is connected but nothing happens on my computer. what should i do??????
  • Anonymous Aug 30, 2008
    computer does not reconise mp3 player I have no cd rom
  • Anonymous Oct 15, 2008
    mine is doing the same thing
    its kinda agrivating me
  • 8,596 Answers
The HDD series is not compatible with Vista or MAC, so that might be your problem right there. If you are running XP, download the software for the device at www.usasupport.philips.com
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
My Go Gear device was charging and then it froze. I tried turning it off, unplugging it, and even connecting it to a different charger. And my computer won't pick up the Go Gear device when I have it...
T osolve this problem, wait until your gogear device dies and wait for 3 hours. after that, recharge your device. This will occasionally happen to this device. (from personal expierience). I recomend the ematic tocuh screen ipod for only 65 $ on walmart. works very good
Jun 25, 2011 | Philips GoGear ViBE Digital Media Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
Doesn't show up when i plug it in to my laptop
To download music or photos on to your Philips GoGear, you need to use a computer that has Windows Media Player and Device Manager already installed. Once these are installed, the steps to sync your Philips GoGear Jukebox using Windows Media Player are fairly easy to follow. Follow these steps to sync your Philips GoGear.
Connect your Philips GoGear to the computer with the USB cable. The USB connector on the GoGear is on the top, and will be on the front or back of your computer. You will see a USB connection icon as soon as the GoGear is connected to the computer.
1.Start Windows Media Player from the Start Menu or from the desktop. To transfer files to your GoGear from your computer, click Copy to CD or Device (with WMP 9) or the Sync tab (with WMP 10). 2.Find the Items to Copy pane. In the drop-down list, click the category or playlist that you want to copy to your GoGear. Make sure that items that you do not want to copy are unchecked. 3.Locate the Items on Device pane. In the drop-down list, click GoGear. When you have selected the items that you want to sync, click the Copy (with WMP 9) or Start Sync (with WMP 10) button.
Apr 25, 2009 | Audio Players & Recorders
Cant find disc to download pictutes
dont need a disc,just plug in your camera via usb or memory card,turn power on camera,click ok for computer transfer on the camera,if nothing happens, go to my cmputer find the removable device thats new in your computer, right click on it,click open,then double click on dcim, next double click on sscam.your picture should start to appear.good luck.hope i helped
Apr 16, 2009 | Samsung S860 Digital Camera
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear Mp3 player problem
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Jan 04, 2008 | Philips GoGear HDD060 MP3 Player
My cmputer is a mac
Hi All,
I had faced this problem too. Apparently there is a solution to this, you would have to install xnjb. Philips gogear uses MTP protocol, which is supported by mac. You will have to install xnjb.
http://www.wentnet.com/projects/xnjb/
Dec 25, 2007 | Audio Players & Recorders
Phillips GoGear not turning on
-Tha Mp3 Doctor
Nov 29, 2007 | Philips GoGear HDD6330 MP3 Player
Philips HDD1630 MP3 Player Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
