Question about HP LaserJet 1320 Printer
Printer cartridge won't snap in
I've replaced the printer cartridge on my laserjet 1320 a number of times, but not in a while.  For some reason, it isn't working this time.  I removed the old cartridge, pulled the tab out of the new one, and then slipped it into place.  The left side of the cartridge appears to be willing to snap into place, but the right side -- where there are various tabs and connectivity stuff -- will not.  As it is, the door won't close.  I tried reinstalling the old cartridge and am having the same problem with it.  Any suggestions for what I am doing wrong or what I might try?  Thank you.
  • PSRLA Aug 26, 2008
    I ended up taking it in to have someone look at it.  They managed to fix the problem by removing the right side of the printer and fiddling until a gear retracted (in their words).  This sounds much like what you have suggested.  So thanks.
  • 138 Answers
The toner sensor mechanism in the printer is not retracting up. It's a fairly common issue. Look in the top right corner of the toner cartridge cavity in the printer. You see an appartus hanging down. Gently toggle it up a few times and ensure it freely moves up and down. Usually you can toggle it up a couple times and all is fine.
Hope that helps you.
Posted on Aug 26, 2008
Printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Dec 12, 2011 | HP LaserJet 1320 Printer
I have HP LaserJet 1320. It has worked fine for one year. But now whenever I take a print it prints a black line of one inch width. I have to clean the cylinder for every page. Can you please help me that...
Two thing we have to observe, is it cartridge faulty? or Printer?..
> Replace with another cartridge check the quality. if it rectified replace with another cartridge..faulty cleaning blade in catrdige cause of vertical lines in print outs..
> Might be teflon sleeve got damaged, replace the teflon sleeve if available or else replace fuser assm..
Oct 05, 2011 | HP LaserJet 1320 Printer
Does not print
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 26, 2010 | HP LaserJet 1320 Printer
How do i reset my hp laserjet printer 1320 to its factory settings coz its printing faint and the cartridge is new and original?
It may be a defective cartridge regardless of its age. Did you remember to remove the pull strip on the cartridge? Is it getting more faint as you print more? If yes, replace the cartridge.
Jun 25, 2010 | HP LaserJet 1320 Printer
1320 printer given blank print hjo wcan i solve
This may be because ink is clogged in the print head. Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty.
Mar 27, 2010 | HP LaserJet 1320 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
I cant print from hp laserjet 1320, orange light is always on.
there is something wrong in your cartridge may be its empty.. replaced a new one
May 19, 2009 | HP LaserJet 1320 Printer
My LaserJet printer prints lines or streaks on every page
Can't read the entire heading for your post, but it sounds like a defective toner cartridge. Replace it.
Apr 25, 2009 | HP LaserJet 1320 Printer
Blank paper affter print out
If there has been no printing since the ink cartridge was inserted, check the cartridge to be sure that the clear tape was removed from the print head. Also, be sure that the cartridge is seated properly.
If it had been printing before, then it sounds like the cartridge is either empty, dried out, or defectice. Try replacing the ink cartridge.
Jun 18, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
146 people viewed this question
Ben Johnson
