Question about Philips GOGEAR SA6045 MP3 Player
Head phone jack only plays right side/brad new headphones
Headphone jack only plays rightside/brand new headphones
  • 8,596 Answers
Call Philips, get replaced - this is a common problem across all mp3 manufacturers. You can look at the YouTube video on repairing mp3 player headphone jacks, but i doubt it will work without causing more problems with your mp3 player.
Posted on Aug 26, 2008
SOURCE:
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
I plugged in my headphones and it only plays sounds on one side.
there is a head phone jack in the front and the back. have you tried them both?
Jun 15, 2017 | Dell XPS Computers & Internet
Headphones
Hi
Try them in another device to eliminate a faulty jack, if they still dont work the head phone may be faulty, return to seller and ask for a refund or replacement.
But also try a different head set in the jack to see if the jacks working properly.
Cheers
Nov 23, 2012 | Steel Series SteelSeries 7H Headset -...
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
Hi! I have a brand new Coby headphones (haven't been a month). I've been keeping good care, but today I found that left ear works perfectly while right one is loose. As I turn the jack at the end around...
try cleaning the connecter
10 Headphone Repair Hacks - Sustainablog
https://sustainablog.org/2015/10/10-headphone-repair-hacks/Oct 19, 2015 - For instance, here's a file for a new jack cover. Reconnect a wire to the lead. If audio is only playing through one side of your headphones, then a loose or disconnected wire is the culprit. Repair the ear cushion. If the cushion wears out or comes off of your headphones, don't worry-that's fixable! Replace the ...
Jan 21, 2018 | Coby CV-190 Consumer Headphones
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Nov 17, 2009 | Onkyo TX-SR876 Receiver
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
Music only goes into one side of my headphones
you have a bad head phone jack
http://www.ipodhowtovideo.com/video/videoheadphonereplacement.html
Dec 17, 2007 | Apple iPod MA446LL/A MP3 Player
Headphone jack
Your best bet is to find a shop that repairs Ipods. Your headphone jack is breaking away from the printed circuit board and needs resoldered. Shouldnt be too expensive. My shop would charge $25-$40 for a repair like that.
Sep 08, 2007 | Apple iPod MA446LL/A MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
346 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
