Baumatic 23 in. BDW13 Built-in Dishwasher Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in, checked the filter, salt, etc, used tablets, gels ... nothing seems to work. Dishes just not clean !
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
289
Points
Lower washer not working but upper washer is. This is due to the dishwasher thinking it is on half load. the sensor is faulty and you need to replace the whole unit (water circulation pump). However if like me and your not bothered about having a half load and always use both trays on your dishwasher you can fix it. remove the dishwasher unscrew the side panels and remove, unscrew the bottom panel. Tilt it on its back and then unscrew the feet and remove the bottom panel. There you will see the water circulation pump. On the top is a sensor with 2 white and 1 orange wires going to it, unscrew the sensor and underneath remove the white plastic valve/flap and its supports. with the valve/flap removed replace the sensor and build it back up. Now the water will flow through both cambers (upper and lower).
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Jun 18, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
770696
Points
7758
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Water in the bottom dw smells.It's not from wet dishes dripping.It just appears every few days.Would my disposal have something to do with it?I don't know how to take it apart to find out.
try washing without dishes with a cup of vinegar or get a product at the store call dish washer cleaner that you use it in and empty dish washer to clean and remove smell.
also could be clogged strainer in the bottom of DW then need to be cleaned out!
43helpful
9answers
Samsung DMR78 dishwasher makes a grinding noise at the beginning of the wash cycle as well as the rinse cycle. Also comes up with the code 9E on occasion.
Check the brackets that hold the top rack for any broken plastic brackets. My dishwasher was making the same noise and after noticing the broken plastic pieces I pulled out the dishwasher put it on its side removed a white panel on the bottom that is attached with two screws, removed the drain line and inside there were two plastic tabs from the broken bracket. Once those were removed the grinding noise stopped. The bracket holding the drain hose can be removed with a pair of pliers.
2answers
My dishwasher leaves a white chalky film on the dishes after washing
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
2answers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 • Dishwashers
2answers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
2answers
Dishes not coming clean, film ring on glasses and dried grime on the utinsels. Have run through twice with vinegar, not sure what to try next. Checked basket/drain and it was not blocked just has a small...
That sounds more like a problem with your soap not disolving completly. Try these few simple things. First, run your hot tap at your sink until it gets hot, then start your dishwasher. What this will do is ensure that your "prewash" is using hot water.
The next thing, is you want to select the "heated wash" or "hi temp wash" option with a "normal wash" cycle. What the heated wash will do is ensure that during the main wash the water gets boosted to 140 degrees wich is the temperature that your soap breaks down at.
White film left on dishes is a classic indication that the soap has not disolved or broken down completly.
3answers
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
2helpful
3answers
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
5helpful
2answers
GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
3helpful
4answers
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
