Question about Brother CS-8060 Computerized Sewing Machine
Brother CS-8060 Were is the reverse sewing lever or button?
If you are looking at your machine there is a trio of "buttons" it the one on the right looks like an upside down u with an arrow pointing down on the right side... press that for reverse...
Posted on Jul 17, 2009
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
I have a brother cs-8060 sewing machine but I don't have the manual for it. When I start to sew the machine makes a loud sound the and woont sew normally and then I get an E6 flashing on the machine.
An E6 error indicates a thread tangle. Combined with the noises you are hearing my guess would be that the tangle is around the take-up lever pivot and is seizing the machine (causing an overload - hence why it won't sew). The origin of this is often a further thread tangle between the tension disks, which has allowed the thread to fly loosely around the take-up. Your best bet will be to take it to your local sewing centre. This is the sort of issue we commonly address as a part of servicing. You will find a description of what you might try in the Service Centre section of our shop's website http://www.kornacraft.com.au/sewingcentre-under-the-covers/
Feb 06, 2015 | Brother CS-8060 Computerized Sewing...
Why does error F7 flash on my brother cs8060 sewing machine and how can I fix it?
Any "F" error message, F1 through F8, can indicate machine is malfunctioning and needs servicing. You can check with Brother.
Sep 02, 2014 | Brother CS-8060 Computerized Sewing...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
E-4 error Brother
Error E-4: The reverse/reinforcement stich button, needle position button or thread cutter button was pressed while the bobbin winder shaft is moved to the right
Mar 28, 2010 | Brother CS-100-T Computerized Sewing...
Mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Aug 22, 2009 | Brother CS-8060 Computerized Sewing...
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Brother CS-8060 Computerized Sewing Machine Logo
109 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
