Question about Oster 76974-160 Hair Trimmer
How do I replace my Oster Housing for my hair clipper
    Problem Solver:
  • 7 Answers
There is not a replacement housing for this item number.
Posted on Jun 01, 2009
I need replacement blades and guards for oster hair clippers model number 4401B?
Fixya does not sell replacement blades and guards for oster hair clippers.
Sep 11, 2017 | Oster Health & Beauty
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I was shaving my dog using oster ultra cordless clipper, and suddenly the clipper is not cutting hair instead it grabs hair. I opened it and clean out hair under blade, but unfortunately, i did not help.
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
Aug 25, 2011 | Oster Health & Beauty
I have oster titan clippers. The brass anchors for the blade mounting mechanism are pulling out of the plastic housing. How do I fix this?
ok if the brass inserts are allowing the hinge to move away from the clipper this will obviously cause a few problems, you will need to replace the body housing (new housing comes with a different design) you can view the clipper parts here
Aug 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
My oster 76 clippers will kick out the two screws that hold the blade holder on
do the screws undo or do the brass inserts pull out of the body housing which the retaining screws fit into.
if the screws undo put some thread lock on the threads.
if its the brass inserts you will need to replace the mainbody.
Jan 23, 2010 | Oster 76076-010 Hair Trimmer
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Oster 76974-160 Hair Trimmer Logo
35 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
