Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
It is the problem in LCD display.Most probably Display is not usable any more.Anyway Contact the service centre and check there is any problem in LCD connection if not replace LCD display
The problem could be the CCFL lamp, especially if the image has a pink hue.
Check LCD Parts for service, parts and DIY info. use this link :- www.lcdparts.net
This is due to backlite problem of LCD panel.
You may approach authorised service center for this issue they will solve your problem. Do not try to do yourself unless you have sufficient experience on LCDS.
If the LED display screen on your printer is blank please try disconnecting the USB cable from the computer and then disconnect the power to your printer. Reconnect the power to a different power outlet, and turn your printer back on. If the same issue occurs, your printer will require service. call HP support so that they can recommend you to a servicer that specializes on the product. Pls rate as fixya, thanks!!
