Question about SanDisk Sansa e200 MP3 Player
My computer will not recognize my mp3 player while it is in MTP mode
If I plug my MP3 player in while it is in MSC mode, the device will appear in "My Computer" but when I plug it in while it is in MTP mode, nothing will appear in "My Computer" and I need to access my MicroSD card.
Not even the player itself will appear.
What do you think is wrong?
It did this once before, but somehow the problem was solved, and it worked fine. Now it's doing it again.
Windows XP.
  • Anonymous Aug 29, 2008
    the player will not pop up at all when plugged in and it use to before i reformated my computer
  • Anonymous Sep 26, 2008
    nothing pops up when i plug it in
  • 4 Answers
Keep plugging it in and out STOP once u see the icon then go to properties, tools and error check
Posted on Aug 26, 2008
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix.
Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
May 17, 2010 | SanDisk Sansa Clip MP3 Player
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager 1. Right-click My Computer, and select -- > Manage.
Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <--
Copy this address into a new window.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
Why won't my Sansa Media Converter recognize my Sansa e250 Mp3 player?
Mine won't read it in MTP mode. It works for me in MSC mode though.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Deleting demo songs
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them.
DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
Apr 20, 2008 | RCA S1000 MP3 Player
Deleting
If your listening to your mp3 player on the computer, then you can't delete any songs. Exit out of the music player and then delete all of your songs.
Dec 03, 2007 | RCA S1000 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
