Question about Insignia IS-LCDTV32 32 in. Television
IS-LCDTV32 32 will not stay powered on
IS-LCDTV32 32 went dead a month ago. Sent in the tv for service and they said I had to replace the circut board. I declined for 400 bucks and did it myself for 30 bucks. Now I power it on and it will not stay powered up. Red light comes on, no blue light and no picture.
  • 2 more comments
  • jp6106 Aug 25, 2008
    Same thing. The red light is on and when I try to turn on the tv, the blue light comes on for a second and then back to red with no picture. UGH! I've tried unplugging the tv and then plugging back in, but this doesn't help.
  • skidmcmurray Aug 29, 2008
    light turns from red to blue ......but no picture
  • amizade345 Sep 14, 2008
    after the tv is off for a week or so it will stay on again but if I turn it off it does the same thing . Power on blue lite blinks once and goes back to red .
  • Anonymous Sep 18, 2008
    powers up then goes dead with red light.
    Need Scematic.
    rodisgod
Same problem, I ave been told it is a diode in the power supply but need a scematic to find out the value on the diode. Help please?
Rodisgod
Posted on Sep 18, 2008
    Problem Solver:
  • 8 Answers
Went dead? no power light? if you had no lights at all its probably the power supply, if you had a red light then I would go with the main board. Disconnect the lcd panel from the main pcb and inverter and see if your blue light stays on. If so you have a bad panel.
Posted on Aug 21, 2008
SOURCE:
Controls not working on Samsung TV. No remote, no TV side either
Fault at its main digital board again. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Just replace its SMPS board [Power supply board] too along with the main board. A faulty power supply board will make the main digital board too bad.
Sep 11, 2016 | Samsung Televison & Video
Gentlemen; We purchased a 32 inch hygh def TV app 3 years ago. We had an issue with a burned out 32 inch model and had a certified repair tech come up to our home and had the main board replaced in I...
Please note that we are not affiliated with any company. We are a bunch of independent consultants with hands on experience at fixing stuff. However if you can get me the make and model of the tv along with country of residence I can get you the contact info of the customer service department so that you can get it replaced.
Oct 31, 2010 | Televison & Video
My vp322 visio will not power on
Power supply in your TV went from bad to dead. You can remove rear cover and try to locate bad capacitors (they will have bulged tops instead of flat ones). Replace them and see if it's going to resurrect TV. If not - whole Power Supply board have to be replaced.
Regards.
Russ.
Apr 04, 2010 | Vizio VP322 32 in. Plasma TV
All three lights blinking picture only stays
I was having this same problem - power cycling - exactly as described. The lamp turns on and the picture looks good for the 5-10 seconds it is on (this makes me question all the comments I've seen online saying it is a bad lamp that needs replaced).
Problems started with green lines on analog channels and erratic behavior that included freezing and shutting off occasionally. Now, it is to the point where I get 5-10 seconds of picture, then it freezes and starts the power cycle 5-6 times, chiming every time it automatically turns on, before finally remaining off. I have removed the back, dusted off fans/components/etc, supplied additional fan for airflow, and made sure the blue switch in the back is down. Still having the same problem!
Ok. I went through the standard warranty process, which means they sent me a replacement bulb saying that was the issue. No luck...same power cycling. Finally they sent a tech out who took a look and said he needed to replace the digital board. So, 2 weeks later, the part came in and the repairman came back out to install it. Voila, I have a tv again. (This is the same fix the supervisor at the call center said it needed months ago...before they sent me the lamp)
So...I would recommend having the tv's digital board checked. Especially if your tv is still under warranty, as it cost me $0.00 to fix. Chances are, they are still going to start by having you replace the lamp. Good luck!
Jan 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 42'
More likely the backlight inverter board has gone out, or power supply for the inverter board went out, those are the two places to look. Check the power supply first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Nov 12, 2009 | iLO 3200 32 in. LCD Television
I have a 42" sanyo plasma flat panel tv. I was watching, and all of a sudden the screen went black. I did still have sound. I messed with the remote for a few minutes...then heard a pop...then tv was...
hello, you have a (shutdown circut) it happens when the tv senses trouble in the circut.
becuase these type of tv's run hot at high internal voltages parts can become overheated and loose proper resistance or ability to handle voltages that have to reach other parts of the circut and other internal board panels. a shutdown it is for protection. you may want to check your power supply if there was a pop that is something inside that went bad. be careful to touching inside theres is high voltages stored in the components.
i can not tell you specifically what your primary cuase was without your model service manual. no power means power supply trouble.
replace or trace.
what ever blew out cuased the power supply to go bad you will need a service manual to know for sure.
the wise chioce is to have a service center check it for you they will know what to repair or exchange.
good luck hope this helps
Jan 08, 2009 | Televison & Video
Power won't stay on
hello. you are not alone, this is a common problem with alot of new lcd and plasma tv's since they operate with high internal voltages the circuts have built in protection. any slight power fualt or short in the circut will cuase a sos or shutdown. may be a number of different reasons or even a shorted fuse.
it needs to be checked you have a power issue.
some models if there is a blinking led the number of blinks indicates the fualty area.
your tv needs service.
hope this helps
Dec 17, 2008 | LG Televison & Video
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Dec 03, 2008 | Vizio GV42L 42 in. LCD Television
Projector Doesn't Power-ON
Hi bmosai
Yes you will have to replace the lamp.
The Projector will shut down and stay off as a safety feature.
May 04, 2008 | Panasonic PT L711U Multimedia Projector
My PROTRON LCD PLTV 32 IS BLACK & DEAD
I had a pwer supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is [email protected].
Dec 29, 2006 | Protron PLTV-32 Television
Insignia IS-LCDTV32 32 in. Television Logo
296 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
