Nokia 6600 Cellular Phone
Problem for Nokia 6600
Nokia 6600 Problem
By Jimmy NY - usenet poster
I have a Nokia 6600 and I have a problem starting it up
everytime I switch on all that happens is the Nokia logo
appears and disappears about 4 times then it switches off
I cant even switch it off myself when it is trying to start
up.
Can anyone please help me with this problem  :(   :(   :(
Thanks in advance
Albertz
albertz58
Cell Phone Forums: http://cellphoneforums.net
View this thread: http://cellphoneforums.net/t17 6899.html
Same Problem
Nov 30, 2009
-   My phone doesn't even switich on.. I mean it turns on the white flash light stays on and the nokia logo reamains.. nothing after that...what shall I do.. I tried the 3 button format..doesn't work either.. what shall i do.. please e mail me ...
billno1@live.co.uk thanks
-   billno1
Apr 10, 2009
-   i cannot pay audio files in my 6600, i copy the audio file from the pc through my memory card and my ultra mp3 needs registration -   kulkris_20
Dec 05, 2008
-   yes the nokia 6600 starts up and then only the logo nokia appears ,, nothing else happens,if i try to switch it off it doesnt go off,,...wat can be done plz advice??-   willbri3012
Oct 27, 2008
-   my nokia 6600 allways turn off automaticly.... even i had change a new battery n fomart it with hard fomart
-   amir08wan
Jul 10, 2008
-   no signal -   Guest
Best Solution
posted on Aug 23, 2005
Very Helpful)
Horner
Rank: Apprentice
Rating: 0%, 0 votes
"If it doesn't help u than proceed with three key boot up format trick,
u
will loose all user data but u will get back your phone..."
-=[ apocalypso ]=-
I can't find the three key boot it doesn't matter if I lose all the
data
______________________________­______________________________­__
"I haven't had any experience with this - have you tried any of the
6600 codes that Gus posted yesterday?"
Casper
I can't get my phone on to get the keypad to work
Jim
albertz58
Was this helpful?
Yes
No
Solution #2
Helpful)
paulrmc
Rank: Apprentice
Rating: 0%, 0 votes
On Sat, 28 May 2005 11:17:50 -0500, albertz58
Try to boot up in safe mode without MMC....
If it doesn't help u than proceed with three key boot up format trick, u
HELP! 6600 doesn't boot and i can't format
http://www.symbian-freak.com/f orum/viewtopic.php?t=557&highl ight=tric...
nokia 6600 wont start up
http://www.symbian-freak.com/f orum/viewtopic.php?t=218&highl ight=tric...
Hipe this helps,
Cheers,
Apoc
######### portfolio #########
Get more guides and advice at:
Symbian Freak introduces various researches for symbian users like:
- Error Fixes,
- Modding,
- Guides,
- Tutorials
- Ask guru form
- and offcourse a detailed forum with professional support for every single user.
To get more out of your favourite device, visit the website.
Don't take life too seriously
you're not going to survive it,
anyway
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Oct 10, 2007
Helpful)
gizmo11
Rank: Wiz  Nokia Expert
Rating: 80%, 591 votes
U must have installed some applications which might be not compatable with H.set os.Remove MMC & then try to switch on Ur H.set.If this works take the data back up & remove the third party applications.In future try to install authorized applications .
Was this helpful?
Yes
No
Solution #4
posted on Nov 01, 2007
Helpful)
Turo
Rank: Wiz  Nokia Phones & Accessories  Expert
Rating: 84%, 99 votes
your phones boot IC is faulty you will need a technician to set it right no way you can do it alone boss
Was this helpful?
Yes
No
Solution #5
posted on Mar 30, 2007
Helpful)
krizanto81
Rank: Master  Nokia Expert
Rating: 79%, 114 votes
the 3key format trick is pressing the calling key+*+numbr3+the power button... press it until the nokia logo and formatting appear. when its still not working visit your trusted service engineer nearest you
Was this helpful?
Yes
No
Solution #6
posted on Oct 28, 2007
Somewhat Helpful)
shepherd
Rank: Guide
Rating: 75%, 21 votes
try the 3key trick..it will format your phone..if it doesnt work..look for a good celphone technician..
Was this helpful?
Yes
No
Solution #7
posted on Oct 11, 2007
Somewhat Helpful)
duxxyuk
Rank: Wiz
Rating: 89%, 71 votes
Safe mode on a Nokia S60v3 is to switch it off. Hold down the ABC key and whilst holding down that key turn on the phone.
Keep ABC depressed until it asks for your pin and you should be good to go.
Was this helpful?
Yes
No
Solution #8
posted on Jun 07, 2008
Not Helpful)
Guest
Rank: Apprentice  Phones & Accessories  Expert
Rating: 0%, 0 votes
my nokia6600 not boot help me
Solution #9
posted on Mar 18, 2009
Very Helpful)
bathiya
Rank: Apprentice
Rating: 94%, 4 votes
Check bsi line it ok . And flash the Phone (Erease)
Was this helpful?
Yes
No
Solution #10
posted on May 03, 2009
Somewhat Helpful)
teroc
Rank: Master
Rating: 92%, 15 votes
Hi Friends,
Having problem with Nokia 6600? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia 6600 problem is for Unlock CodePuk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia 6600. Such as software problemhardware problem etc. If you having these problem you can Click Here. May you find your solution.
Was this helpful?
Yes
No
Solution #11
posted on Aug 18, 2008
Somewhat Helpful)
skgarg
Rank: Apprentice
Rating: 75%, 1 votes
try this, swicth off the phone and then prees *,green,3,and power, there will show formet on screen
Was this helpful?
Yes
No
Solution #12
posted on Dec 15, 2008
Not Rated)
jainik_1990
Rank: Apprentice
Rating: 0%, 0 votes
teashark web browser is not working in my nokia-6600?
Was this helpful?
Yes
No
Solution #13
posted on Sep 07, 2008
Not Rated)
filip randy
Rank: Apprentice
Rating: 0%, 0 votes
i wanna break my all codes on my cell phone nokia 6600 plz send me a master code to breake a phone code plz
Was this helpful?
Yes
No
Solution #14
posted on Jul 14, 2008
Not Rated)
drperson
Rank: Apprentice
Rating: 0%, 0 votes
i am unable to connct my pc with nokia 6600,through blooth,it connect,the data of the cell can't displayed on moniter of the computer,some one says it is software failure, any one inform how we reinstall nokia 6600 software, other wise send nokia 6600software to my mail id .ravi_kumar2634@yahoo.com,so please help me how to reinstall nokia 6600software,and where we get that software inform wesite of the nokia 6600 softwares
thanking u
ravikumar.p
srisailam project
kurnool(dt),andhrapardesh,india.518102
Was this helpful?
Yes
No
Solution #15
posted on Mar 14, 2008
Not Rated)
dheeraj_64
Rank: Guru  Nokia Phones & Accessories  Expert
Rating: 86%, 77 votes
format ur m.card and cell on u.f.s software
or format wid 3 kys(calling ,*,3& power on/off)
Was this helpful?
Yes
No
Solution #16
posted on Feb 05, 2008
Not Rated)
coolvikki20
Rank: Master
Rating: 80%, 17 votes
this is a problem with the corrupt software....go 2 a nokia store nd get the software reinstalled..
Was this helpful?
Yes
No
Solution #17
posted on Feb 04, 2008
Not Rated)
musafirkmr
Rank: Apprentice
Rating: 0%, 0 votes
hello this problem is a mobile virus attak your mobile .pls your mobile formating procegure after format the mobile phone this poblem not appear .not that lost all data in ur mobile phone .before formating yor phone all phone numbers and other files,sms back up .and remove memmory card and sim caed .after press * 3 call butten ,on off swich also a disply "formating". not insert ur memmory card after formating memmory containse virus format ur memmory card and inserted
Was this helpful?
Yes
No
Solution #18
Not Rated)
vivek1234
Rank: Master
Rating: 68%, 6 votes
u have flashing problem
flash your mobile and even if it doesnot work then your boot ic is failure
Was this helpful?
Yes
No
Popular Solutions for Nokia 6600 Cellular Phone
Questions and Unsolved Problems for Nokia 6600 Cellular Phone
Do you recommend Nokia 6600?
Answer
Answer
cara membuat tema nokia 6600??
Answer
When i copy mp3 song to 6600 mobile by bluetooth,opens in ultramp3 player & i can't save... (More)
Answer
Hello Sir, Please Give Me Smart Movie personal Liences key my smart movie serial Is 357932005421337... (More)
Answer
how to clean slide mechanism nokia 6600 slide it is gritty?
10 Other Users Have The Same Problem - Continued
Comment by joshg204, posted on Jul 08, 2008
Hi
when i start up my Nokia 6600, it flashes up with the word Nokia, and then goes to a blank white screen and does this for about for times. It also sometimes in the transition between the 'Nokia' phase and the blank white screen it flickers with thin black lines down the screen
I've tried booting it up without the MultiMedia Card in, but this does not help.
If anyone could help me with my problem that would be great cheers
Josh
Comment by pkind, posted on Jun 12, 2008
3 key bootup
Comment by Guest, posted on Apr 02, 2008
sir,
i have a nokia 6600...when i switch on the phone,the nokia logo appears and fades away...this happens some4times.v cant do anything abt it.the phone wont startup beyond this phasei removed my mmc card and tried to restart but to no avail.
kindly help me out
thnx
Comment by Guest, posted on Feb 08, 2008
up.
Comment by r_edition99, posted on Nov 21, 2007
up.
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
in Burnsville, MN
(845) 363-6459
Cell Phone Repair - At Out of Warranty, we are...
Out of Warranty Repairs
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
