Question about Compaq Computers & Internet
Loud fan noise maybe bearings..only 5 months old new
My fan is heating badly what i do?
Posted on Oct 24, 2011
  • 22 Answers
Usually loud fan noise in computers means that the fan you have got is too fast for you computer or too slow for your computer. go back to the place you got your fan from and ask them to check its compatibility with your computer.
otherwise try cleaning the fan or removing it and making the screws a little bit looser. might jusdt be rubbing
regards matt
Posted on Aug 21, 2008
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Loud Jet Engine Noise
Erik? Do you either live next to an airport or on an approach pattern? Just wondering! No really...IF Your machine is making THAT much noise! Jeeze! You have a balance drum bearing gone! Maybe more. There are usually four of them located on the corners of the drum. They are throw away and buy new anywhere from $20-40 each. If you have no idea what I am talking about and your machine is over 7 yrs old. Get a new One!
Jan 16, 2014 | Washing Machines
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
My portable AC/heater is making a LOT of noise, intermittently and loudly. Then it returns to normal volume, only to return to loud noise level later on. What might be the cause? Mobilair MA-9000AH - six...
it can be the fan which is at times going unbalanced and vibrating the body of the unit. It will be when the fan is touchin the sides of a metal part that the noise seems to come up.
Since the noise can be traced to the source of origin, it will be good to carefully open the set out and test.
If the blade are causing the issue, clean and set, if not the bearings/bush must be defective,
Sep 03, 2010 | Heating & Cooling
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Loud rumbling noise in mastercool a/c
could be the fan is full off dust or something causing it to be out of balance
May 19, 2009 | Mastercool 67471 Evaporative Cooler Air...
Squealing NOISE possibly from fan belt
Belts stretch from new. Try to tighten them again. Hopefully the are not glazed or this may stay with you.
Dec 14, 2008 | 1988 Dodge Grand Caravan
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Computers & Internet Logo
512 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
