Question about Vacuums
Was vacumning watershut off switch would not start again water level was well below the ball
ShopVac QPS series,Quiet Deluxe, 10 gals, 2 1/2 HP
Left the top assembly which includes the motor out side in the sun for 2 days and this am it started. cwcb
Posted on Aug 21, 2008
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
Lost manual for shopVac 5.0 QSP deluxe
go to www.retrevo.com or www. fitness.manualsonline.com
God bless you
Jun 18, 2012 | Vacuums
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
WHAT IF THE SHOP VAC IS BLOWING INSEAD OF SUCKING
Check for blockage and make sure that the hose is in the correct port.
Mar 19, 2010 | Shop Vac ShopVac 3 HP 2 Stage 10...
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Over heating?
it sounds like you need to replace the motor in it . thank you for using fixya
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
