Question about GE JVM1650 1000 Watts Microwave Oven
Possible blown fuse
The oven was started and ran for about 3 seconds, then nothing. We've checked the house fuses and that it was plugged in correctly. The oven is just a little over a year old and had been working fine up to this point.
  • 7 more comments
  • cyntait Aug 21, 2008
    The oven is a JVM1650. We were able to get the fuse out, but can't tell if it has blown. I don't know what a blown ceramic fuse would look like.
    This is the second oven of the same we've owned. The first died with a loud thumping noise and were told that it was the magnet that had failed. We decied to purchase a new unit instead of having it fixed.
    We didn't experience any thumping when it died this time.
    Does this help?
  • rcline734 Aug 29, 2008
    My JVM1650 runs for a few seconds and the resets and asks me to set the clock. When it first started doing this it would be ok after setting the clock but now it is consistently stopping after a few seconds. I am trying to determine if it is a thermal switch or magnetron or if I should just bring it in for repair or buy a different model. I see many reports of folks replacing the magnetron multiblr times. Is there a procedure for isolating the problem ?
  • Anonymous Oct 23, 2008
    the jvm 1650 soacemaker xl microwave oven stop working I cheked the braker its working it is a fuse how do i fix it
  • seahagg Nov 11, 2008
    I have the same problem with my GE JVM1650SH01 microwave - runs for three seconds then quits - I have to reset the date/time, etc.. Is it the fuze? How do I change it? Thanks!
  • jayg714 Nov 15, 2008
    My JVM1650CH01 does the same thing it runs for about three seconds and then stops. The display becomes garbled and the clock/calender has to be entered.
  • cfr1 Nov 29, 2008
    my microwave jvm1650 was working fine - then while i was reheating something it just died. it came back on for a few seconds and died for good! The house fuse is fine and we check the socket. There is absolutely no power - no lights no power....nothing!! This unit is only 3 years old. can this be fixed or will it be too expensive?
  • abbyrife Dec 10, 2008
    Have a GE JVM1650, this is the second time that we have had this problem.  The microwave runs for about 3 seconds and then the whole thing shuts off.  We have to re-set the clock and then try to run it again.  It does not happen every time we use it.  The first time this happened (about 6 months ago) my husband found some website that told him to remove the control panel, and put a piece of tin foil in a plastic bag between the magnatron and the control panel.  This seemed to fix the problem until recently.  Is there anything thing we could test, or are we better off replacing it?
  • Anonymous Dec 23, 2008
    My JVM1650 has the same problem in that it runs for 3 seconds and cuts out. Usually, the display flickers a little before cutting out. The ceramic fuse is good as well as the thermal fuse and safety switches. As a test, I've shorted each one at a time but to no avail. Just about the time that I give up, it's working again for a few months.
    I suspect that firing up the antenna is causing an internal voltage sag that confuses the electronic controller board, and an essential relay cuts out.
    Actually, I was hoping to find a used JVM1650 so that I can start
    swapping parts, but again, it starts working again just when I give up.
  • William Miller
    William Miller May 11, 2010
    Is this a GE JVM1650? If not, Please reply back with your brand and model number so we can help you.
    I would suspect the fuse has blown, or possibly the magnetron thermal cutout (TCO or thermostat, depending on which it has.
    I need your correct model to continue.
  • GE Master
  • 9,086 Answers
It would have to be checked with a multimeter or continuity tester.
Posted on Aug 21, 2008
Reset button
Unplug,then plug back in,wait 10 minutes,or try another outlet,circuit breaker could of turned off at control panel in house,reset it.
Mar 04, 2017 | Microwave Ovens
Sharp Carousel Convection microwave
Are there any display lights?
If not check your house circuit breaker. Check main
Fuse inside microwave. If fuse is blown check damper diode and HV capcitor, magnatron.
Dec 28, 2014 | Microwave Ovens
My micro/oven/grill (ed8525s-sbd on rear) will not turn on. after using the oven feature around 20 seconds after it had done it tripped the kitchen sockets and set the house alarm off. the fuse in the plug...
It's likely that some part of the microwave has gone short circuit and blown the main fuse. The fuse is a 7000 volt glass encapsulated inline fuse housed inside a tubular plastic case about 2 inches long.
Renew the fuse and switch on. Look out for anything that is not functioning and replace that part, eg, fan, light, turntable motor etc.
Jan 29, 2014 | DeLonghi MW 605 Convection/Microwave Oven
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
Oct 09, 2010 | Viking DMOR205SS Microwave Oven
No power or functions of any kind.
Check the external fuse / circuit breaker first.
IF that is OK, then it's possible an internal fuse has blown. These can be replaced but it should only be attempted if you are confident enough to be able to discharge and ground the main capacitor before working on the device.
Mar 23, 2010 | Whirlpool GH4155XP Microwave Oven
I believe mine blew a fuse as well
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
many people have been electrocuted with an unplugged microwave due to the enormous residual charge inside.
you can now get a new microwave at walmart for fifty bucks..........why monkey with a ten year old unit.
Aug 17, 2009 | Sharp R-963 Convection/Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
858 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
