Question about Sony Handycam DCR-TRV130 Digital Camcorder
Cannot eject tape
Power works fine, however when I hit the EJECT button on the camera it does nothing and I cannot get my tape out? Please help.
There is a little blue swich under the cover, i need to lift the cover press the switch and it may or may not open, I am now using a small 6" sraight edge under the cover , but I trigger the litle blue switch and works evey time. BTW, I made a mark on the outside so I know where to lift and press to open with my straight edge.
Lifting the cover does not work.
Posted on Sep 05, 2008
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
Tape will not eject
a small spring (eject spring) is getting dam or missplace due to that you having the problem
Nov 11, 2008 | Sony Handycam CCD-TRV58 Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Eject Button does not work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 10, 2008 | Sony Handycam CCD-TRV608 Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Nov 13, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Sony Handycam DCR-TRV130 Digital Camcorder Logo
118 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
