Question about OKI C5650n LED Laser Printer
How do I reset fatal error code 980 on a oki c5650
  • 1 more comment
  • ngarita_h Jun 18, 2011
    I only got some adhesive paper wrapped around roller it is all off didn't even get any residual adhesive left stuck on the roller can I over ride the fatal error code I don't believe anything is damaged
    Hi The LED screen seems to be stuck on SYSTEM MAINTE when I power up with both + and - Menu buttons together what should I do
    Can you help with the "system mainte" when I push + and - when I power up? I really need to get on with my printing if not I'll have to look else where for help
    Thanks
    Ngarita
  • 1,216 Answers
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Posted on Jun 18, 2011
  • Aviral Saxena
    Aviral Saxena Jun 18, 2011
    1. Turn machine on while pushing and holding the TWO up/down menu
    buttons at same time.
    2. Menu window will show "OKI USER"
    3.
    Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
    4.
    "Diagnostic Mode xx.xx.xx S-Mode is indicated.
    5. Scroll to "NV-Ram
    initial" is indicated. Push ENTER.
    6. Window shows "NV-Ram- Initial
    Table 1".
    7. Push ONLINE and ENTER Buttons simultaneously and HOLD
    for 10 seconds after you see "Executing Reset" appear in menu window.
    8.
    Restart printer.
  • Aviral Saxena
    if this is the case it is a faulty toner and you cannot get on without replacing it
SOURCE:
Oki c5650 in Engine diagnostic mode can't find NV Ram need to reset 980 fatal error code -sheet of paper got wrapped round Image drum need to reset it
You cant find the reset because there is not one. OKI do not use resets to cure errors. Yes a 980 is paper wrapped around the hot or pressure rollers in the fuser. Normally you just take out the fuser and remove the paper and it will start working. However this MUST be done with the power OFF. So it should be a case of just turning it off and removing the jam and refitting the fuser and turning it back on. If the error is still there then alas a new fuser is require to get it going again. You may be able to buy a fuse from suppliers on the net, fit it and that will do the reset without the need of buying a fuser.
Jul 06, 2018 | OKI Office Equipment & Supplies
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on [email protected] and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
OKI C5650n LED Laser Printer Logo
14,364 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
