Sc 322 error
There is an sc322 error on my savin 2535 that i need to fix. i know it has something to do with the laser unit but don't know how to trouble shoot it.
  • Paul Onyisa Aug 21, 2008
    The copier is out of service and on its way out. I only need to print the documents that are stored in the Document Server. Is there a way to get the documts out without having to print them?
  • 2,794 Answers
Troubleshooting a laser is a lot of work. You're better off getting a tech that can do it safely and correctly. That error code has to do with the motor.
Posted on Aug 21, 2008
  • Tim Babcock
    Tim Babcock Aug 22, 2008
    Is that printer connected to a network?
Functional problem sc 322
Laser unit problem.clean polygon Morton assembly and optics of laser unit,if error still comes then replace polygons scanner.
Feb 10, 2015 | Ricoh Aficio Office Equipment & Supplies
Sc 322 error
The first this I would do is remove the the front access door, and then the panel that is behind the access door to gain access to the laser unit. Most likely what you have is a bunch of toner and/or developer all over the laser sync board. Use a toner vacuum to clean this up, and your problem will most likely go away, unless there is something wrong with the board itself, but this is rarely the case. It's almost always buildup on the sync board.
Below are the details of the SC322.
SC322: 1st laser synchronization error
The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor I/F harness connection between the laser synchronization detector board and the LD unit.
• Laser synchronization detector board out of position and angle of reflection not correct
• Laser synchronization detector board defective
• LD unit defective
If you don't know what any of this is, call a professional, as you could mess the MFC up even more by messing around with it.
Jun 13, 2013 | Ricoh Aficio 2035 Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
SC322 on Savin 4035
Laser synchronization error. It could be just toner on the LD unit. Try cleaning and doing the Pitch adjustment. If that doesn't work , then either the unit itself is bad, or the Sync. Detector board.
***This will obviously require a tech.
May 04, 2009 | Office Equipment & Supplies
Funtion problem
Sc 322 means there is a problem with the laser unit,and 99% of the time it is the polygon mirror motor within the laser unit. You have 2 options.Replace the entire laser unit which is in a neat little black box and is relatively easy to replace. Better yet,merely replace the mirror motor which is enclosed within the laser unit. But one or the other must be replaced as there is no adjust/oil/clean/tinker/fudge to be done. I wish I had better news but really the news aint bad and the advice is free so if you have to get "copier dude" to come out he/she wont try to hose you !!! Well they might try,but YOU know better. :-) hope this helps,take care. .......spinal.......
Mar 25, 2008 | Office Equipment & Supplies
680 people viewed this question
k24674
jasbo
jasbo
