Canon imageCLASS  MF3240 All-In-One Laser Printer Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blicking light canon d480 - Canon imageCLASS MF3240 All-In-One Laser Printer
Sudeep Chatterjee
Level 3:
  • Canon Master 3,267 Answers
  • Posted on Jun 18, 2011
Sudeep Chatterjee
Canon Master
Level 3:
Answers
3267
Questions
10
Helped
1158297
Points
10260
Try this
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
How do I load the printer cartridge in the printer
Go to page 180 in the [ImageCLASS D480 e-manual]. It will give you pics and steps for changing the cartridge. Also if you keep the download you will have the manual for this printer.
imageCLASS D480
1helpful
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Cannon imageCLASS D480....will not work at all, just gives error code E225...how do i fix this?
it is related to CIS unit and SCNT Board. check it. if it is demage you require to replace it.
1helpful
Canon D480 document feeder doesn't always feed documents
First, try changing some Document Feed Rollers etc.
FC8-9251-000 is the pickup roller
FL3-1023-000 is the separation pad
FM3-8679-000 is the feed roller
That would fix 80% of the problems you may encounter
Whit
Item, Inc.
2helpful
Why do I have a black line on my copies? I have the Canon imageClass D480 Multifunction copier
Pull out the toner crg., and if there are streaks on the drum, replace crg. If there is no streaks on the drum, clean the copy glasses.
Can't get our Canon D480 to work with our fax
ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
You need a regular phone line.
old marine
old marine
ZJ Limited
ZJ Limited
