Question about Lexmark Office Equipment & Supplies
Hardware error code 0502 - Lexmark Office Equipment & Supplies
  • 14 Answers
HI try this its from the lexmark web site.
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Posted on Aug 21, 2008
SOURCE:
What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code [email protected]
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
May 24, 2010 | Dell A940 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Getting hardware error 0502
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
send you the link where you can figured out
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
0502 error on my Lexmark All in One Printer
lexmark 5150 code hardware error 0502 what can i do
Dec 18, 2008 | Office Equipment & Supplies
Hardware error message
Here is a link to the error code that you are receiving and it includes a troubleshoot. http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=true&docid=3448BE8E41616B39E040A68F5B28300D&journalid=18CBB4A8572211DCAEB7A5F38B3D0A57&l=en&s=dhs Hope this helps:) Jason
Aug 30, 2007 | Dell A940 All-In-One InkJet Printer
Open Questions:
261 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
