Question about Shop Vac Vacuums
Motor stopped running - Shop Vac Vacuums
  • 19,396 Answers
First ensure the vacuum had not stopped because the bag is full, check also that the hose is not obstructed.
If the vacuum does not start at all, check the wiring contacts to the motor, and check the start switch.
If there is no problem on switch or wiring , then the mottor is faulty and you need to get it replaced.
If you need to call a technician use the number printed on user manual.
Regards
Posted on Sep 03, 2008
  • 13,433 Answers
Possibly cut wire, or broken down motor, would need to be inspected, looked at, repaired or replaced.
    Genius:
  • 2,920 Answers
Have you checked the crankshaft positioning sensor?it will stop the car from running and getting fire
Posted on Aug 21, 2008
It was working fine and then all of a sudden stopped. The power switch still lights up but the motor doesn't run. What could be wrong?
you didn't state your model so I can't be specific to your model. It could be a loose wire, reset switch, bad motor, worn motor brushes, fuse, switch, etc.
You'll have to check to insure power is making it to the motor and if so why the motor isn't running.
May 01, 2016 | Vacuums
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
Miele s658 stops running when hose plugged in. How do i fix this?
1) Check if some debris or clogged is inside trying to stop the motor.
2) See the belt if break, or need replace.
3) Motor need repair.
sincerely. God bless you.
May 08, 2012 | Vacuums
Vacuum runs 10-11 minutes then stops if you unplug for a minute it then runs for another ten or so minutes then stops again I heard it was the bypass switch what can I do
Hi, I would say the motor is overhesting and there is a heat sensor in the motor that shuts it off w3hen its labouring. Check your hose for a clog . If that does not help check the filter aorund the motor to see if it is clean. Hope this helps. Chris
Feb 21, 2011 | Numatic HVR200P Bagged Canister Vacuum
Motor stopped running...i have veard this could be
I have the same shop vac with the same problem. I have disassembled it and can tell you the motor core windings go to two posts of what appear to be some sort of fuse, and that's where the open circuit is in mine. (I bypassed it to test the motor, and it started up fine). Now I'm trying to figure out whether that fuse can be replaced.
Jul 04, 2010 | Vacuums
My bissell ran over the cord and stopped sucking
The belt probably broke or stretched and that is why it stopped working. Here is the belt you need:
Bissell Lift Off Belts
Feb 07, 2010 | Bissell 3750 Lift Off Bagless Upright...
The motor won't run. There was interupted running
What model#? Plus check to see if their is a reset switch, sometimes on hoover the switches do go bad, but if the unit is new could be still under warranty
Nov 23, 2009 | Hoover Vacuums
Motor won't stop running
You have a bad relay board. An Electrolux dealer can get you a new one.
Nov 10, 2009 | Electrolux Central Vacuum
Vacuums Logo
226 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
