Question about RCA DRC8030N
Remote does not work
I thought that the remote may have gone bad. Bought a new one, but still it does not work. Guess something may be wrong with the unit. The unit works itself manually. I can use all the functions such as eject/load dvds by pushing the buttons manually.
I have the same problem. the unit itself won't accept the remotes signal. i tested 2 remotes on 2 different machines, and the problem machine won't accept signals, but the good machine will from both remotes.
Posted on Sep 16, 2008
Here is a trick i use to see if remotes are working. most people these days have camera phones or some kind of digital camera that have a live picture feed mode before they snap an image. Grab your camera of choice and point the remote at the camera while your viewing this live feed. press any button on the remote in question and you should be able to "see" the infra red led light blinking. if you dont see any blinking then the remote is the problem. try different buttons if you dont see anything at first.
Posted on Sep 13, 2008
I bought the swing for my daughter and put new batteries in. Music works but it won't swing at all. What is wrong? I hate that I spent 60 dollars on something that doesn't work.
It's likely the motor gone bad. The contacts inside the motor can get burnt out and prevent the motor from turning. Did you buy the swing brand new, or was it used? If you bought it new you should return it for a refund.
Dec 14, 2010 | Summer Infant Just One Year Travel Swing...
My remote control stopped working ,new batteries did not help...even tried a new one, still didn't work....any thoughts...
Get auniversal remote or a new original. If your handy you could take apart the bad one and look for bad solder contacts (or something spilled in it)
Sep 21, 2009 | Philips Magnavox 27MS343S 27" TV
No monitor display
there is something wrong with your ram....take it out n clean it with rubber....den agin hook it up in its place...after dat it ll work....otherwise u need to replace ur ram
Sep 01, 2009 | Intel D101GGC Motherboard
Can't get any remote to work for my Mitsubishi WS-7390573
You could always download a universal remote app from Google Play that should work. Hope this helps you
Apr 01, 2017 | Mitsubishi WS-73905 73" Rear Projection...
Remote control will not work
same problem but new remote won't work at all. I have a Magnovox TV and Journey's Edge remote.
Feb 19, 2009 | Sony DAV-S300 System
Samsung remote control
Remote control problem: your going to laugh at this but this was an easy fix, after my husband told me that there was something wrong with it, I tried to use the remote and he was right, it wasn't working. I changed the batteries that evening and sure enough it still wasn't working. The next day I had a closer look and thought that it wasn't right that a new t.v. remote wouldn't work, and lo and behold the problem? My housekeeper put a picture right in front of the electric eye of the t.v.! Guess what, it works quite fine again, thank-you for your time, and I am glad that it wasn't anything major. Peggy
Jul 22, 2008 | Samsung TV Remote Control
RCR312W problem
I believe the remote is losing its program. Have you tried to reprogram the remote?
Jul 09, 2008 | Televison & Video
Remote Control not working for MW24FM3 Toshiba
I have the same problem with my unit. I use the original remote and my Tivo remote. Both stopped working at the same time. Ocassionally they will work for awhile then stop. They always both work or both don't. Therefore it must be the TV; likely the sensor or something connected to it. Sorry I don't have a solution. Guess I need to take it to the shop.
May 07, 2008 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
My remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Jul 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
RCA DRC8030N Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
