Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor we have had this monitor for a few years now and it is starting to wake up very slow until it reaches full brightness. what do you think is going on. thank you george
  • Anonymous Dec 14, 2008
    I have the same problem, it takes a long time to wake up after computer goes idle, any solution what to do next?
  • hyrumz Dec 25, 2008
    Yes, I have the same problem on my SyncMaster 204B it wakes noticeably slower and flickers some. I've had it for about 2 years
    Problem Solver:
  • 6 Answers
Have the same monitor and had the same problem. The problem is bad electrolytic capacitors in the power supply circuit. Replace C110 and C111 and you will have the problem fixed. The original caps are 820uF at 25V and they are in parallel for a total of 1640uF. I only had a 1000 and a 560 and placed them in parallel. All is good now.
Get this fixed before it takes out other parts in the power supply. Took me about 30 mins. Good luck,
Ryan
Posted on Jan 06, 2009
Why projector takes time whe it is started
Depends entirely on what you mean by "takes time". These projectors require a few minutes to reach full brightness, and many models even activate an LCD shutter to black out the image until the lamp has reached reasonable brightness.
If you mean it takes several minutes to produce any picture at all, it may just be time to replace the lamp, as it may not be striking (starting the lamp) correctly due to a fault in the lamp starter circuit or the lamp itself. In the absence of a detailed fault description, my best guess is that it's most probably a tired lamp :o)
Apr 07, 2014 | Philips bSure SV1 Multimedia Projector
22 samsung syncmaster S22B150 led monitor color settings problem how to fix
I have the same monitor. It was working just fine for almost a full year and recently I started to play games on Furg Games Play Free Online Games for a few hours a day and my eyes started to hurt. I've tried to change brightness and contrast several times but still I can't stay more than an hour in front of it.
Oct 11, 2012 | Samsung Computers & Internet
For many years, my monitor will flash too bright ocassionally. And it will stay too bright until I jiggle the whole monitor. I thought it is the connection in the back of the monitor, and if I jiggle this...
there is the problem with ur mother monitor mother board i.e. solders get moistures u have to re soldering the all the components of ur monitor mother board.
best solution is the, go to the nearest electronics repairing shop near by u.
May 29, 2011 | iiyama Vision Master Pro 450 Monitor
Prior to this past week my Samsung SyncMaster 225BW monitor's display came on almost instantly when turned on. Now it takes at least 30 seconds to reach full brightness. What is the most likely cause ...
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Dec 16, 2009 | Samsung Computers & Internet
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
How do I brighten the screen. It is very dark.
Okay on you monitor there is a button there you press its labeled with a little picture of a monitor with a arrow on it or in to that regard you push that button and there should be onscreen menu you use the + and - to scroll to the correct function you want once you done that you should be able to save your settings. This is all done on the monitor!
Please do click the accept button if this helps , Thanks
Nov 05, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Monitor problem - Dark colors, slow screen refresh
It sounds to me like the picture tube in the monitor is going out. I began to wonder if it was your video card until you mentioned that you used it with various computers. This tells me it's the monitor itself. Unfortunetly, I think your monitor may be due for retirement.
Oct 22, 2008 | ViewSonic VG900b 19" LCD Monitor
Computer monitor
I have the exact same issue with the f1703 monitor - the OSD will not turn off. Apparently, this model monitor was defective, and was recalled by HP. However, they failed to give notice, so I would recommend following up with them to attempt to get it replaced. Good luck!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jun 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
210 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
