Question about Brother Office Equipment & Supplies
My machine will not turn on or off or do anything. It is displaying error message: Machine Error A7. Any ideas what the error message is and what I need to do to fix it?
  • Anonymous Sep 23, 2008
    I had the same problem after fixing an error 46 with the info I got oh here. When I put it back together I put one of the cables in backwards. Once I changed that it was fine. Works perfect now. Not sure if this will help you or not.
  • prplskydiver Sep 23, 2008
    I got this error after fixing an error 46 with info I got on here. When I was putting it back together I put a cable in backwards. Once I fixed that it worked fine. I am not sure if this will help you or not though.
    Problem Solver:
  • 4 Answers
I have discovered the hard way that the start-stop switches on many electronic devices do NOT turn the power on and off. There is always power being supplied to the unit when it is plugged in. Try leaving it unplugged for a couple of hours and fire it up again.
Posted on Aug 21, 2008
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Konica-Minolta bizhub 215 giving c3451 error message?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
How do i clear message c2558 for the konica minolta bizhub 215
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Feb 24, 2014 | Office Equipment & Supplies
Initially the machine showed a fuser error. after opening the machine moving the fuser back and forth and restarting the machine did a self diagnostic and came back with the message - "machine error,...
Press menu, start, menu and the up arrow one at a time in order. Maintenance should appear in the display. Arrow down until you see 82 and then press the menu button. A machine error number should be displayed. After getting the number press the stop key to get it out of maintenance mode. The error that is displayed will determine the problem. What number do you see?
Jul 13, 2011 | Brother MFC-8660DN 5-in-1 Laser...
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Machine error A7
A7 says that the scanner information in the eeprom is corrupted. The scanner is the wrong type. You will need a shop to do the eeprom clear in the diagnostic mode.
Jul 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Machine error AE on brother MFC 6800
The error is from the scanner. It is possible the scanner lock on the underside of the scanner has shifted and not allowing the scanner to correctly return to the home position. Try Checking the scanner lock and make sure it is not in the locked position. Then turn off and on your machine while holding the menu/set button. the machine will come up either with an error or in maintenance mode. either way enter 99 and see what you get. Maintenance mode is a dangerous place to play around in. 99 exits maintenance mode. 91 resets all parameters to factory setting except stored locations like phone numbers and location information. 01 resets every thing to factory. DO NOT CHANGE ANYTHING IN MAINTENANCE MODE. CCDHP is scanner home position sensor. It will probably reset just by turning the machine off and on.
good luck.
Nov 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Office Equipment & Supplies
Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
123 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
