Question about Roper REX4634KQ Electric Dryer
No heat motor turns
Where is thefuse, heating element or what breaker
  • babybearsmoo Aug 28, 2008
    thanks almostbob i think i might have fixed it thanks to you. it seems to be getting hotter than i can remember it being .
  • 550 Answers
Most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this no heat motor turns - 93a9e30.jpg or like this 4b96964.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or meter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
Kenmore dryer 11062062100
If a dryer is not heating - and it is electric, then the first thing to check are the breakers. It runs on a double breaker and half of the breaker may be good (allowing for other functions other than heat). Half breaker will run motor and timer but the element needs both breakers (220v). If that is not the issue, then element may need to be inspected.
Apr 11, 2014 | Dryers
I have a creda tumble dryer and its not heating up i replaced the heating element but it's still not heating up
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in?Check for blown fuses or tripped circuit breakers--your dryer uses twofuses or circuit breakers. The dryer could tumble but not heat if onlyone of the two fuses is blown. If you have circuit breakers, one of thetwo circuit breakers can trip, even if the two for the dryer areconnected.
Heating element Oftena dryer heating element burns out, but doesn't trip the circuit breakeror blow a fuse. The heating element is simply a long coil of specialwire. You can check it for continuity with an ohm meter. No continuitymeans the element is bad and you need to replace it--electric heatingelements aren't repairable.
Thermal fuse Onmany dryers, there's a thermal fuse mounted to the exhaust duct insidethe back cover panel. The fuse--which is about an inch long--is usuallyembedded in black resin and mounted in a white plastic housing. If thefuse has blown, you need to replace it. (You can't re-set it.)
Wiring Acommon problem is for the main wiring connection from the house, at thedryer, to burn and break its connection. Because the dryer can stilltumble with partial power, the connection may be only partiallydefective. You may need to replace both the power cord to the dryer andthe terminal block inside the dryer that the wire is attached to.
Sep 02, 2008 | Dryers
My whirlpool model LTE5243DQ6 is not heating up. i turn it to the max heat and it doesn't heat up. it turn on and i could hear the clothing moving but it not heating up.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Feb 10, 2011 | Washing Machines
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Samsung d665jw electric dryer won't heat
does the drum turn but no heat? very first thing to check is the BREAKERS! flip them both on and off several times, then back on and try it. 9 times out of ten, ONE of the breakers has tripped, the motor will run [120volts] but the element will not heat up [240volts]. if that's not the case, check the thermal fuse, the element, and the safety switch - replace as necessary
Aug 16, 2009 | Samsung Dryers
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Dryer flips the breaker ran 4 1 year and nothing changed started this 2 days ago any idea about the
If its tripping your breaker either the motor is seized for some reason (easily tested by trying to turn the motor pulley by hand), or something in it is shorted out, most likely thing to short out and trip a house breaker is the heating element.
You can easily test the heating element as the possible cause by taking the 2 wires off the element connector, tape up these wires so it doesn't short out, plug the dryer in and try to run it. If its the heating element shorted out then the dryer will now run without tripping your breaker but of course not heat. If so replace the element.
Mar 09, 2009 | Kenmore 62602 Electric Dryer
Dryer
When dryer does not heat, or heats too slow, that means that there is a problem either with the heating element, the thermal fuse
Unfortunately the only solution is testing and eventually replacing either the heathing element or the thermal fuse. Both jobs must be performed by a technician.
If you insert model number here you can get replacement parts and exploded view.
See the following suggeations from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Oct 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryer Won't Start
most common problem with the dryers is blown thermal fuses, something gets too hot and for safety reasons the thermal fuse blows. You can also check your incoming power supply make sure the breakers havent tripped. part num( LA-1053 )about $30 comes with directions to install. its located under main top towards the rear of unit moundted to the side of heater.BE SURE TO TURN OFF ALL POWER BEFORE CHECKING ITS LIVE!!!!!!!!!
Mar 06, 2008 | Maytag PYE2300AY Electric Dryer
Roper REX4634KQ Electric Dryer Logo
65 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
