Question about Philips GoGear HDD6330 MP3 Player
My MP3 Player not turnning off
I have Mp3 Player Philips 4GB GoGear and when I want to change music,Go to the Main Menu or turn off , but it is not work,and also when I connec to PC it saids that No device connected
  • 8,596 Answers
Make sure the lock switch is off. Reset method is power on plus volume + at the same time for 5 to7 seconds.
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Posted on Sep 14, 2008
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
Describe your GOGEAR SA6045 (4 GB) MP3 Player Problem My son installed music in my player. He is now gone in the Army & I can only turn on the radio. Don't know how to get to music installed
Turn on your player and you should see and listen to radio. In this situation press menu key and then select music icon and the select for example all songs. Finally press play button.
This picture will help you finding the menu key:
I hope I helped.
Thanks.
gylacz
Aug 24, 2011 | Philips GOGEAR SA6045 MP3 Player
How do you turn it off. Philips 4GB GoGear Flash
There should be a switch near the bottom, the same switch that allows you to lock it. You just pull it the other way and hold it down. A message should display that it is shutting off.
May 10, 2011 | Philips GoGear Flash MP3 Player
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
My mp3 player turns on but goes blank as soon as the music comes on.
Change the backlight settings in the Settings menu of the GoGear if the music continues to play when the screen goes dark.
Otherwise, if the music also goes off when the screen goes blank, run a Repair in the Philips Device Manager.
Mar 31, 2009 | Philips GoGear SA3125/37 MP3 Player
My Philips GOGEAR SA6045 MP3 froze up after adding music on it ?
My 4gb philips froze on the part were it say gogear i cant start it
Oct 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Is it possible to download music to the Philips GOGEAR MP3 4gb player WITHOUT windows xp?
You would have to go on the site and download the software for Windows 2000 ( I saw they have a version for Philips Manager for other versions of Windows)
Jan 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
