Question about HP 1020 Plain Paper Thermal transfer Fax
Copier won't work
The paper won't feed through.
  • Anonymous Feb 27, 2009
    paper won"t feed in when rtying to fax!!!!!
Press the solid ICON that looks like the ink cartridge
Posted on Aug 21, 2008
Paper is not being fed from paper holding drawer. sometimes makes clicking sound. Copier does work when single piece of paper is fed through right hand side of machine
It sounds like the feed tire is dirty, OR the feed clutch has sprung. Remove the paper tray On the right side of the copier where you feed the single sheet, you pull down the door. This exposes a fat gray or black feed roller. Take a clean dry towel and dampen it with wd 40. Gently wipe the roller with the cloth turning the roller toward the paper exit direction. Let the WD 40 soak in for ten minutes, replace the paper tray and try to make a copy. If it does, you need a feed roller which will rquire a service cal/take it in. If still no feed the 'clicking' may be a sprung clutch, service call required.
If this helps, please let me know with a vote, thanx
Jan 30, 2011 | Canon PC-980 Color Copier
Paper jam from paper drawer
Has the copier ever been cleaned, professsionally? If not, you may need a feed roller.
Unplug the copier. Prepare a dry cloth dampened with WD 40. Take out the paper tray.
Pull down the door on the right side of the copier. You will see a single, fat, gray or black rubber roller. Take the WD 40 cloth and wipe down the roller, turning it in the direction that the paper comes out the machine. Close door and install the paper tray. Let the copier stand for ten minutes.
Plug copier in and try a copy. If it feeds the paper, you need a new feed roller. If it doesn't then remove the paper tray and shoul there be skid marks on the paper then for sure you need a feed roller. If the paper continues to feed hooray, but when it stops feeding you definitely need a feed roller.
This requires a service call unless you have some experience with copiers. Likely this puppy needs a thorough cleaning.
Jan 25, 2011 | Canon PC-941 Copier
Copier will not feed copy paper from tray into copier?
you might have a paice of paper blocking the feed tires,pull your paper tray out and look in the copier whear the tray goes in to see if you have a sheet of paper in their.
Apr 21, 2010 | Sharp AL 1631 Copier
Paper error on a Sharp Z75 copier. Will not pick up paper from the tray, but works fine single feed.
If you can find the parts for the copier, I would replace the paper tray paper pick up rollers and the paper feed clutch. From what I remember, it is a little tricky to replace these parts. You may just want to use the manual feed tray.... Good Luck
Aug 09, 2009 | Office Equipment & Supplies
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Copier Jams
Sounds like feed tires are dirty or warn-out. if you can see the rubber piece that feeds the paper, Inspect if it looks dried-out or has imperfections try to clean with rubbing alcohol, use the most lint free cloth as possible. This can also happen when using office depot or staples or CHEAP PAPER These papers carry a lots of paper dust try switching paper. If none of this works the feed tires proberly will need to be replaced contact a local copier company: Chuck The Copier Guy
Aug 09, 2008 | Office Equipment & Supplies
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
HP 1020 Plain Paper Thermal transfer Fax Logo
62 people viewed this question
Seeker5211
Seeker5211
