Question about Kenmore 64802 Top Freezer Refrigerator
Fridge too cold
I have an old Kenmore with top freezer.  With more people living in the house recently, the fridge has been jam packed. First it leaked on the floor, which I cleaned up, including drain pan, but couldnn't find anywhere it might be plugged.  Now it's freezing the vegetables: lettuce, leeks, etc.  There's ice on the thermostat control, which had been set to least cold, but is now set (as of this morning) in the middle of the dial.  Any suggestions? I hope I don't need a new fridge!
  • 833 Answers
First, clean it the unit out and fully defrost.  Clean the condenser coils.  Don't pack in so much food, don't open the door too frequently.  Never block any air channels. Never leave uncapped liquids in the fridge or freezer.  Set the fridge at about 40 degrees...use an outdoor thermometer.  Freezer at about 0-5F.
Posted on Nov 20, 2008
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Kenmore 106.52572202 not cold
You moved the refer from one house to another, did you clean the refer first? was there a dusty old piece of cardboard hanging off the back? that cardboard needs to be in place for proper air flow through the condenser coil.
Jul 17, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Fridge not getting cold
Hello swill688
Welcome to fixyz
You said, Your Kenmore refrigerator not getting cold
What is the model number?
And how old is it?
First check that the freezer is not filled packed full, and covering the air passage vents in the rear of the freezer! The fridge and the freezer share cold air from the compressor.
and his can cause the fridge to get warmer.
The other 2 things may be, either the coolant is low and needs to have the pressure checked then perhaps a sot of freon.
Or the thermostat may be malfunctioning!
I hope the freezer is packed to full, this is the easy way out of this situation!
Let me know!
Please remember to leave a rating before you leave us!
Thank You, Huuum
Sep 30, 2008 | Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
