Question about iLO MP3 Player
I cant delete songs off of my mp3 player
I go to my widows media to delete songs and it just comes up as the sync list what should i do?????????? The comptuer says that the device is disconnected when I try to delete songs. I can sync the songs though
  • 2 more comments
  • ginpookie Dec 14, 2008
    kid used device but has inapproprate music on it how do i get them off.
  • bachus308 Dec 14, 2008
    i can not delete songs off of my ilo mp3 player
  • Anonymous Apr 05, 2009
    It says delete error every time i try to listen to a song.
  • ginpookie May 11, 2010
    there is no solution here what do i do???
I can't delete my songs. I have tried 4 different media player to delete and they all give me an error message. Failure to delete, not responding can't delete etc... What should I do? I have the pink ilo 1GB mp3 player
Posted on Aug 21, 2008
How to delete songs
There's no way of directly deleting a song on the player. You need to do it either via Windows Explorer, or a music manager program which "syncs" to your player.
To delete a song via Windows Explorer, connect your Sansa to your PC, open up "My Computer" (or "Computer" if you're running Vista), and you should see your Sansa listed there. Double-click on it. If you then see "Internal Memory", double-click on that. You should then see a list of folders including "Music". Double-click on that, and you should see a list of songs. If you see a list of folders named after your Artists, double-click on the appropriate Artist folders to find the songs you want to delete. Select the song(s) and press "delete" on your keyboard.
If you use a music manager program such as Windows Media Player, Media Monkey or Winamp to sync music onto your Sansa, just delete the song from the music manager library or playlist(s) you're syncing to your Sansa, then do another sync.
Feb 17, 2010 | SanDisk Sansa e200 MP3 Player
I cant figure out how to take songs off my mp3 player
connect your usb cable to you computer. go to my computer and open the removable disk drive folder that shows the name of your device. Once you open the folder it will show you all the songs in your device. select the songs you want to delete and remove them by clicking the delete button on your keyboard.
rhea
Mar 16, 2009 | Sony NWZS616F Digital Media Player
I cant delete anything or upload
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In the Device Setup Wizard, select Manual.
3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
4. Select the Library option. On the left pane select Sync List.
5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
6. Select the songs from the center pane, and drag them to the Sync List.
Dec 01, 2008 | GPX MW3836 MP3 Player
Deleting music
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Jun 19, 2008 | SanDisk Sansa m240 MP3 Player
Cant Delete Songs
Thank You
Computerrep
Apr 17, 2008 | SanDisk Sansa e260 MP3 Player
Downloading
I use Windows Media Player v11. Select the "Sync" tab, then you can list the songs that are already on the mp3 player, delete any that are not required, and put other songs on there by putting them in the sync list and pressing the "Start Sync" button.
Jan 06, 2008 | SanDisk Sansa m240 MP3 Player
I cant delete any songs off of a MyMusix PD-6110 MP3 player....
Q: How do I delete songs from the PD-6110?
A :The songs only can deleted through your PC. If you use Windows Media Player 10, go to the Sync window and select the songs that should show up under the 'Music' folder tree on the right side of the window and select the songs you want to delete and press the 'delete' key on your keyboard. With Windows Media Player 11, Open the 'MP3 Player' tree on the left side of the window then select 'Songs' from the list. Then select the songs you want to delete and press the 'delete' key on your keyboard. You can also open the 'Removable Disk' under 'My Computer' and delete the songs from there.
Nov 26, 2007 | Audio Players & Recorders
Cant delete
Here's how you get it
you may have to open Windows Media Player but maybe not
a screen will come saying for you to choose either NO leave all the media on the device... or YES delete all media.
click YES but MAKE SURE you have the HOLD button on OFF. if you dont... it will not work
after it completes the task click FINISH
i tried for hours trying to figure it out and that made it work like a charm! =]
Nov 02, 2007 | GPX M2104 MP3 Player
Cant Delete
well putting songs on your MP3 player is easy its taking them off thats the problem, so here are some easy steps to doing so. 1. plug in your MP3 player to the computer (USB) 2. go to my documents 3. scroll down to other 4. click sansa m230 5. click TCNANDO 6. then you have an option of Albums, Music,and RECORD click on Music 7. then you have the artists names and all you have to do is click the artist, then the album, and the ones you dont want you right click it and select delete 8. repet that until done deleteing songs of your choice 9. now you can add songs
May 29, 2007 | SanDisk Sansa e250 MP3 Player
did you try going into (if you have a windows pc) My Computer, and navigating to where your player is (your player should be hooked up to your pc via a usb cord - the one that came with your player). your player could be in a removable disk - mine is (J:), or it could be under Other (all of this is still in My Computer). Click on different removable disks if you have to, until you find the one that has your player. Once you have found your player, double click to go inside it. Inside of your player should be a list of folders. One of them should be named Music. It could also have a Playlists folder, an Audible folder, or a Pictures folder, etc. Click on the Music folder. You should see a folder of all of your songs, OR you will see your song files. Select the ones you want to delete, right click and select Delete, or drag the files to your recycle bin. Hope this helps!
Apr 08, 2007 | Coby MPC-848 MP3 Player
228 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
