Question about Norton Internet Security 2005 (37648246941) for PC
Norton Internet Security 2008
Error in installing. A setup error has occured that requires a reboot. I did the regedit tip but didn't work. What do you suggest. Send reply to Di205@aol.com
  • 871 Answers
Go to symantec site and download the auto removal so that when you try to install again, you wont come across any errors.
what error code did you see? whenever an installation error occurs, there will always be a code. and with every specific code, there will be a solution and fix.
Posted on Aug 31, 2008
I started downloading norton internet security 2010 when it stopped, telling me there was an error.
1. Close the Norton Download Manager.
2. Open the Norton Installation files folder of the desktop.
3. Remove the Norton Download Manager and .dll file.
4. Install the Norton using the NIS setup on the folder.
5. Install the sysupdates to update the virus defenitions.
6. Restart the computer.
7. Activate the Norton using your product key.
Apr 20, 2010 | Norton Internet Security 2005...
Have norton all-in-one-security but won't load
error message actually points to a LiveUpdate problem,which could just be a problem with your installation. Instead of uninstalling Norton and reinstalling it, please try the procedure below.
Please click on the link below and follow the instructions carefully.
Fix for LiveUpdate Error
After you complete the steps in this document, please check that your LiveUpdate settings by doing the following:
1. Launch Norton Internet Security from Start-.>All Programs->Norton Internet Security,> and then choose "Norton Internet Security" from the sub-menu.
2. Click on the "Norton Internet Security" tab at the top of the window.
3. Click on the arrow next to "Settings" to expand it's options.
4l. Next click on "Automatic LiveUpdate." It should say "On." If not please click on it and then click on the "Turn On" button. When Automatic LiveUpdate is turned on, as long as you are connected to the internet and logged in to Windows, LiveUpdate will check for and install updates up to 3 times per day. This is the best way to keep Norton Internet Security up to date and running smoothly.
Nov 19, 2009 | Symantec Norton AntiVirus 2008: Windows
How do i activate the norton antivirus 2009
Firstly downland and Norton removal tool to safely remove installed Norton program
To download Norton removal tool
1. www.norton.com/nrt
or
2. www.symantec.com/autotools download and run first tool
Once we finished the un installation we can
To download Norton Internet Security 2010
1. www.norton.com/nis10
once we finished the installation we can activate with the existing product key If you will get error message like "you exceed number of installation" while trying to activate you need to contact the Norton support to reset the installation count.
Aug 15, 2009 | Symantec Norton Internet Security 2008:...
We have nis 2008 i am not able to install in windows 7 suggestion pls
what error do you get?
It seems the 2009 version is compatible by installing a compatibility update via live update:
http://www.symantec.com/norton/theme.jsp?themeid=windows7
May 19, 2009 | Symantec Norton Internet Security 2008:...
Installed Norton 2009, now only boots BSoD 0x00000024
1 delete norton from your hard
2 run tune up utilities 2008 and execute the registry cleaner
3 open the registry and search anything which have relation with norton for exp : norton 2009 enter
delete the left keys and search them by pressing f3 then delete
reboot the computer instal the antivirus and everything will be allright
rate this if its helpful ;)
May 09, 2009 | Symantec Norton Internet Security 2009
Norton Internet Security 2008 installation problem
Download the Windows Install clean-up utility from the Microsoft site, Install it, run it and select the Norton 2008 product and un install it. Reboot, then try your installation again. Let me know if this works, I have other suggestions if this does not work for you.
Apr 12, 2009 | Symantec Norton Internet Security 2009
Full system scan not getting completed
Open NIS and run LiveUpdate. Keep re-running LiveUpdate until it says that there are no more updates. Reboot the system if prompted to do so (you may want to reboot even if it doesn't say it is required, just to be sure everything got replaced properly). Open NIS again, select Tasks and run a Full System Scan. The error message should not appear again.
Mar 19, 2009 | Symantec Norton Internet Security 2008:...
Problems
hey super
the error happened after the installation right?
what you have to do is go to the symantec site and download the norton removal tool to uninstall your norton. this will help get rid of any anomalies so that your norton can be correctly installed. when installing, you have to stop any other applications from running so that norton will have a larger bandwidth of resources in installation.
check also if your computer have met the required system requirements to install Norton internet security 2008 a.k.a. NIS08.
once installation is ok, go to RUN and type LUALL so that your norton updates will start.
hope this works for you.
Aug 17, 2008 | Norton Internet Security 2005...
I have just had to re install norton internet security 2008 and now it will not start
Check to see if the computer meets the minimum system requirements
    To successfully install Norton Internet Security 2008, your system must meet the following minimum requirements:
    Basic requirements for Windows XP:
    * Windows XP Home Edition or Professional Edition
    * 300-MHz or faster processor
    * 256 MB of RAM
    * 350 MB of hard disk space
for more information check here
How to install Norton Internet Security 2008?
and
further information
http://forums.2cpu.com/archive/index.php/t-87910.html
Jul 01, 2008 | Computers & Internet
i got this norton removal tool from my friend... try removing norton fully using this
http://rapidshare.com/files/88858648/Norton_Removal_Tool.exe.html
and then try installing....
else goto norton site... i think they have this removal tool for free....
Feb 03, 2008 | Norton Internet Security 2005...
Norton Internet Security 2005 (37648246941) for PC Logo
100 people viewed this question
Top Norton Computers & Internet Experts
Alun Cox
Danny Kuhlmann
Are you a Norton Computer and Internet Expert? Answer questions, earn points and help others
