Question about Philips Televison & Video
DVD player stalls, then continues
My player will not play any DVD without intermitant stalling. It will play fine for a minute or so and then stall briefly and then go again. I have no idea what the problem is. Please help.
    Problem Solver:
  • 15 Answers
Chk and see if the the ribbon cable to the optical lens is broken. CHK also to c if the path the lens travel is clear from debree. CHK to c if the loading gear for the lens is moving smooth. CHK to c if the disc motor turning freely and not stopping suddenly. If all of the above is ok then the board could be defective..
Posted on Aug 21, 2008
The DVD player in my 24" Toshiba Combo DVD/VCR TV is working intermittedly. It plays fine for a about 30 minutes ... then it stalls for a few seconds, starts again, stalls, starts again, stalls until...
This can be either a dirty lens or the optics starting to fail. On very rare occasions it is the digital processing section. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that failes to correct the problem, try playing a music CD. If the CD plays OK, I'd suspect that the optics are starting to fail. Reading a CD takes a lot less laser power than a CD.
Keep us posted.
Apr 11, 2008 | Televison & Video
Can you give me some more information? Does it run fine if you do not apply the brakes? This could be a failing brake booster and you are loosing vacuum when the brakes are applied....
Jun 14, 2010 | 2001 BMW 3 Series
Have a 1998 Chrysler Concorde with 134,000 miles. About 2 months ago it started stalling intermitently. Would stall and I could restart immediately. Now it stalls once every trip at a certain engine temp....
your car problem is overheating, some car model like yours is designed to shut-down engine when engine temp. rise so as to avoid frying the engine. your engine overheating problem is attributed by one of these factors:
1. check or refill radiator water if less
2.check radiator cooling fan operation-if damaged pls. change or check the electrical system.
3. damage/ worn water pump-if damage pls. change the water pump.
4. check for any coolant leak somewhere the coolant line-pls. rectify the leak.
5.worn coolant reservoir cap- change if damaged.
6. clogged radiator-if clogged pls. change it.
7. damaged thermostat valve.
May 06, 2010 | 1998 Chrysler Concorde
I am using a DVD player on my PC to view movies under Win XP. Certain discs refuse to open. However they do open on my friend's PC. Also, for all discs that I am able to view, the movie periodically stalls...
I suggest first port of call is a firmware upgrade you need a CD-R to do this and the correct BIN file and flasher from the manufacturers website.
Jan 07, 2010 | Philips DVP3150
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Car starts, drive a mile, stalls.
try haviing your alternator checked advance auto parts can check it while its on the car and the can check the battery too. if thats not it it may stall due to a loose battery connection or a loose ground strap. if it stalls and everything turns of (electrical) it may be a connection or ground strap.
Aug 14, 2008 | 2002 Dodge Intrepid
Picture stalls/freezes
Clean laser lens with canned air Then clean the rubber circular area off (part that disc fits onto) then try to see if it stops freezing &skipping.
Jan 11, 2008 | kawasaki PVS-10921 Portable DVD Player
Televison & Video Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
