Question about Gateway Computers & Internet
I want to restore my computer back to factory specs, and i can't seem to be able to do that. what do i need to do?
  • 22 Answers
Yuou need your disks that came with your laptop/desktop then you need to run the recovery or the fresh install
then you should be good to go.
thanks
matt
Posted on Aug 21, 2008
SOURCE:
Need to reset the sylvania netbook
Make sure your computer is on and working, and also connected to the internet.. Remember you will lose all data when you do this, so back up first anything you need to keep.
There seem to be two lines of thought on this.
1. The reset button on the back is about 1in. diagonally from the right lower corner of the data plate. Insert a tooth pick/a straightened paper clip in the little hole and hold for about ten seconds with the power plugged in. This should reset it to the factory specs.
OR
2. To do a system restore on Sylvania Netbook, you need to make sure that it is connected to a router. After accessing the internet, press "F9" key to start the restore process where it will restart to confirm and then ask for the password.
Mar 01, 2014 | Sylvania Computers & Internet
How can I reset my LG X110 netbook to factory specs?
Do you have anything on the laptop you need to keep? have you done backed ups of any files etc?
To do a factory restore
Press the F11 key when you turn on the laptop (may have to tap it several times)
Then follow the guided prompts to do a factory restore.
Alternate option to do a factory restore:
Press F8 when you turn on the laptop (may have to tap repeatedly)
a menu should come up
choose repair your computer
then select factory recovery/lg recovery?
(source: Link)
Charles
Mar 31, 2013 | Computers & Internet
I want to reboot my dell 1505 inspiron laptop to factory specs. Please help.
Note: restoring your computer to its original factory settings will clear most of the data off of your hard drive, including personal files. Be sure to back up what you need.
Some computers ship without a system restore, but your computer more than likely has it.
To restore your computer to its original state, do the following:
- Make sure your computer is powered off.
- Turn on your computer, and hold the 'Ctrl' key and the 'F11' key at the same time
- When the menu appears, select 'restore'
- If your computer does not have system restore, you will not be able to / not see restore
- Confirm that you wish to restore your computer
- Your system will be reset to its original state
- When finished, select 'finish' to reboot the computer
You will have to go though some of the menus that you did when you originally had your computer. Your computer should finish restoring after these menus.
Mar 30, 2011 | Dell Inspiron E1505 Notebook
I need to do a factory restore on a 1012 mini how? the f8 thing does not seem to work.
you can only do this type of recovery on certain machines --contact manufacturers site for original "specs" etc
Sep 07, 2010 | Dell Inspiron Mini 1012 Netbook PC
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Can't restore to factory spects
Beat me to it pontelemon.....lol.
Just as the Guru said and mine is...see below.
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process.
Apr 09, 2009 | Computers & Internet
Recovery disks, Factory specs, pda files and pcmcia?
thanks for your smile
recovery disc is used for recovering your operating system when your pc is having problem.
restoring back to factory default means the settings of the computer when you received the computer from the shop. in other words default settings.
pda files are personal data assistance files.
pcmcia card is same as lan card( also known as nic card, ethernet card) of your pc. pcmcia card is used in lap tops.
Dec 13, 2008 | Sony VAIO VGN-N130G/W Notebook
Cannot access full factory restore
Open up your Control Panel (in Start menu), click on 'Performance and Maintenance', then in the left-hand column click on 'system restore'. On the system restore screen choose 'Restore my computer to an earlier time' and follow the directions to go back as far as you want.
I'm curious why you need to do this, though. If it's because of a virus, make sure the virus is gone or your problems wilkl just come right back!
I would certainly consider ordering the manufacturer's recovery CD's any way in case the hard drive ever goes bad. It's cheaper than a anew set of 'Windows' CD's. Good Luck!
Dec 11, 2008 | Computers & Internet
I need to restore my computer to factory settings
If your PC is still under factory warranty the manufacterer might do it for you. I did not have the restore disk but eMachines surprised me. by sending me a shipping box and then paying the shipping costs both ways. The PC was restored to factory specs and back to me in 5 to 7 business days.
You will need to include your Windows OS password.
If your PC is out of warranty most manufacterers will sell you a restore disk for about $20 plus
shipping cost.
Sep 25, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
