Question about GE (PSS26MSRSS) Side by Side Refrigerator
Electronics on the blink
We have an error code HRS in the main box, no temps are showing, and the Ice maker, water dispenser are not working. It seems like a circut board issue, but there is nothing to reset on the refriderator.
Does anyone have any insight?
-jab5500
  • 770 Answers
There is a circuit board in the back right side embedded in the unit has about 6 screws holding a cover plate this ill need replaced part # WR55x10552 you can look it up at www.apdepot.com
Posted on Aug 21, 2008
SOURCE:
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker/ water dispenser does not work. Letters HRS blinking on display. Temp control inoperable as well.
looks like a motherboard problem..if its a GE i think they had a recall on it and they will send you one for free
Dec 07, 2012 | Refrigerators
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Apr 08, 2008 | LG Refrigerators
Getting Error Code "er if"
I posted a similar problem with the er if code. I think I have isolated it down to the ice maker fan problem. It appears that the master unit is not getting the correct code from the ice maker fan. I managed to get rid of the problem by dumping the ice, turning the ice maker off (there is a switch next to the ice maker), and unplugging the unit for three minutes and plugging it back in. However, I am without an ice maker. But the problem has not returned and the rest of the unit seems to work normally.
Hope this helps.
Nov 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kltchen aide icemaker
check controls make sure no one has changed settiings should be around middle setting
Is your freezer keeping the right temps?? If freezer temp has changed it will affect ice production, stick themomator and check freezer temp
Look at ice maker make sure theres no blockage of pieces of ice slowing ice maker
Oct 23, 2007 | KitchenAid KSRS25IL Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
231 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
