Question about Refrigerators
Kenmore 50222000 help me please
I am having a weird problem with my fridge. The freezer freezes but the fridge is warm. I have made shure all air access ports and doors are clear. The condenser isnt frozen, turned the fridge all the way up, condenser fan working, coils are clean, fan in freezer clean and working, lights up, and I get water get ice, and the frozen stuff is froze,  but the fresh food side is warm about 50 degrees F. What do I check next. Thank-you for any advice/help you can give This is for a General Electric Refrigerator model number TBX22ZLG. My freezer is working fine but the main refrigerator section is only chilling to about 48 to 52 degrees Fahrenheit. I suspect that something is blocking the cold air from circulating well into the main refrigerator. I have been trying to find a repair manual online for my refrigerator but having no luck finding it. I am looking for a help in finding a manual and/or help with troubleshooting and fixing this problem. Thanks!
My email is bb_hm@hotmail.com. Thanks for your help!
Posted on Aug 24, 2008
  • 770 Answers
Post your email i will send you the manual but souds like you have a defrost problem check the back wall of the freezer for a thick frost build up
Posted on Aug 21, 2008
Fridge side not working, freezer side is fine.making weird noisr
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Kenmore 56983 Side by Side Refrigerator
We have a Kenmore top freezer (no ice maker) refridgerator less than a year old. The frige part is warm while the freezer is frozen. Turns out the vents on the top of the fridge were clogged w ice. We...
Very likely the vents are freezing due to the defrost drain is blocked so instead of the water from the defrost draining into the pan on the bottom as its supposed to its pooling in the freezer and freezing over the air vents.
This tip i wrote will help ya to clear the drain. http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Kenmore Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Freezer freezes, fridge below will not cool
if your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Nov 17, 2008 | Kenmore Refrigerators
Kenmore freeze on the bottom.. model 596-72219200
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Freezer is freezing up.
Have a look at your door seals - if they're not airtight, the fridge will just suck in water vapour and freeze it. A.
Mar 25, 2007 | Kenmore 64522 Top Freezer Refrigerator
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
