Question about Roper RAS8445KQ Top Load Washer
Roper washer issue
Hi, my washer it about 3 yrs old, it just started kicking off. it starts filling with water and then it just stops. i have to bang on it or turn the knob multiple times for it to turn back on,then it washes,and turns off again in the middle of the cycle. its just been stopping in the middle of the cycles. have any suggestions? its not that old so i dont know what the issue is. any suggestions will help. thanks
    Genius:
  • 1,028 Answers
Next time it stops raise lid on right side at edge of opening will be a small opening where lid switch is push down switch with pencil or something small enough to fit if it starts working replace switch ..if switch is not at that location may be under hinge left rear if that is the case ck hinge screws
Posted on Aug 21, 2008
My roper washer stop during after the rinse cycle. Is their a reset button.
remove plug from wall is master reset. but its most likely a sensor or controller issue? get a service manual first.
Aug 21, 2015 | Roper Washing Machines
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Washer stops mid cycle
theres contact points in the timer and down below wherer the wires go into the motor. check them and if you find them to be corroded you canm clean the with emery cloth then reassemble the unit.
Oct 15, 2008 | Roper RAX4233PQ Top Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper won't spin
you need to replace the clutch assembly. requires special tub wrench. and some experience
Jan 13, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
79 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
