Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite error code
Cleaned filter, still have error code and not running.help!
Possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Posted on Aug 23, 2008
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
We keep getting an f35 error on our Kenmore Elite front load washer. Even when we try to restart the load (no soap to rinse it) the SUDS and f35 errors come up. Any suggestions? I don't see f35 in the...
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Nov 26, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer drain problem
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
Getting an F 02 error code with my Kenmore Elite HE 3T
Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,368 people viewed this question
Sal De
fordexpert
Robert Rankin
