Question about Whirlpool Washing Machines
F 6 code on w/pool washer ghw9200lq - Whirlpool Washing Machines
  • 5,911 Answers
The "F06" error code is an indication of a Motor Speed problem. The following link explains this in detail:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The more common fail item is the Motor Control Unit (MCU), but you need to follow all the steps just to be sure. I hope this helps you.
Posted on Aug 21, 2008
    Genius:
  • 1,028 Answers
Ck for connection on main control bd and at motor and motor control bd ..most likely suspect is main control ..bad motor control bds are rair
Our Whirlpool Duet GHW9200LQ washer will not always start a cycle when you press the START button, although it does not give any error code. What's wrong?
I also have this problem. I removed the control panel, removed the green start button, put the control back together and pushed the red button on the panel and the washer works again. I just have to replace the start button.
Jan 22, 2013 | Washing Machines
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
The following link explains how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
My husband is trying to fix the washing machine, and we have DL F code, i know is something to do the the door, but he checked the door and I think that is not the problem!!!!We have a Whirlpool GHW9200lQ...
Mine did the same thing. The plastic part that locks the door is bad. My brother repaired mine instead of calling someone the part was 54.00, and it took him 15 minutes to fix. You could be looking at more than that if you call someone out. The front comes off easy.
May 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a whirlpool ghw9200lq front loader and its locked.
http://www.applianceaid.com/neptune3.html#lock
click the link directly  the brand is mytang in the link but the system is exact same and can be applied on whirlpool brand too. check out.
Apr 03, 2009 | Whirlpool GHW9200L Front Load Washer
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rear shocks whirlpool duet GHW9200LQ front loading washer
ok its hard to remove the shocks without breaking the little tabs. You can tell which way they rotate out right?? There is a stop tab that stops the shock when its locked in. Rotate the other way, I use pump pliers (crescent wrench) and gently apply pressure until the tabs give. The new shock has new tabs and all..
Nov 24, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
