Question about Mitsubishi WT-46807 46" Rear Projection Television
Mitsubishi WT-46807 - blue shadowing
We had this TV fixed last June - new power supply. In the last two months, it's started doing this:
If you can't get this image or want a bigger pic, there is a link here:
http://members.aol.com/b1bbet/tvbad.jpg
You can see the slight blue shadowing and mild bending, too.
It will go away if you turn off the TV then turn it on again. On occasion, it may take 5 or so "flips" to get it to go away but after it's gone, it's okay for the duration. It does come back after cool down.
Ideas?
Thanx. :)
  • Tim Timmins Aug 20, 2008
    Oh, I've seen some posts for similar problems about reflowing the solder on the ICs. Don't know if that would help here but I could do that, I just have to know which ICs and where they are.
  • davidj281 Aug 28, 2008
    Saw you had a power supply problem. Which one did they replace. I think I have that same problem. Thanks!
    Sergeant:
    Champion:
  • 227 Answers
YOU HAVE TO REPLACE THE CONVERGENCE IC'S THERE IS ONLY ONE BAD BUT IT IS RECOMMENDED THAT YOU REPLACE BOTH.
CAYPIANAN@YAHOO.COM
Posted on Oct 02, 2008
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have an older 200x model Mitsubishi 1080i 46" rear projection TV that no longer turns on. When first powered up the power light on the front blinks in sequence to note that I have a bad power supply or...
Parts for older Mitsubishi are difficult to find. If you give me the complete model number I can check if the part is available online.
In the meanwhile please, try the two websites below.
Encompass Parts Distribution
PartStore.com
Feb 10, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsub tv
can you be more specific ? i don't understand your posting. what is the problem with your tv?
Nov 22, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi VS-5005R big screen
I just finished fixing one of this units and there a few thing that i changed, the voltage regulator and 2 capacitors and as prevention repair i did some resoldering in the power supply and horizontal ckt
good luck
caypianan@yahoo.com
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Powering down
THAT'S CORRECT, YOU NEED SOMEONE WITH ELECTRONICS SKILLS TO FIX THIS PROBLEM. YOU HAVE A POWER SUPPLY PROBLEM AND I BELIEVE THAT THE CONVERGENCE IC'S HAVE TO BE REPLACED TOO.SO CALL AN EXPERT IT WON'T COST MORE THAN $350.00
Aug 25, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Burnout ? wt-46807
There could be a Pip problem or the vertical sweep could have went out also so then the set shuts down the video so it does not burn a line across the tubes. Theres really no way to tell what is wrong or it would just be a guess, a shot in the dark. Call out an authorized repair depot and get an estimate. Good Luck
Oct 29, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
