Question about Panasonic SA-HE200 Receiver
System is saying overload more frequently
My receiver is going into overload more frequently than ever at volumes over 30 db. I have outdoor speakers and this is keeping me from being able to use the speakers outside at a reasonable volume
Blow all the dust out of the unit with compressed air to prevent over heating (overload)
Posted on Dec 11, 2008
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
Overloaded. When watching movies or dvd's or TV my receiver will shut down and it says "OVERLOADED". It happens when I have the volume at 50 or more. Am I underpowered? What do I need to do?
your probably overdriving your speakers. unit will detectand set overload when it gets hot or your speakers start to disort out. most amps is at full volume at half volume anyways
Sep 29, 2011 | JVC RX-9010V Receiver
The volume will only turn up to "0" and barely hear a sound from the speakers. How can i trouble shoot this
I had a similar problem with an SR4320 that I bought used at Goodwill. First of all, turn the volume knob down; 0 db is actually the highest volume. Not sure why Marantz did that; it's counterintuitive. Set it to a more normal volume like -30 db. If it suddenly starts working, you'll blow out your speakers (and possibly your eardrums).
Second, check the back of the unit. There are two RCA connections that say "Pre Out" and "Main In". This is where you could connect another amplifier or a graphic equalizer. But if you don't have either of those hooked up, you need to have them connected to each other. Apparently the unit shipped with jumpers connecting these plugs, but a prior owner must have taken them off.
All you need is a short (1 foot or less) red and white RCA stereo cable. Connect the top Pre Out to the top Main In plug with the white cable and the bottom Pre Out to the bottom Main In plug with the red cable.
Hope this helps! It's a terrific receiver!
May 21, 2010 | Marantz SR-4320 Receiver
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
I Have a VSX-917V-k When I put up the volume past 25 it works for a minute or two and then its says overload and shuts off. The speakers are older than the system but they r 15" Technics which work at 8...
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. I could guide you a bit. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further. Thanks for using FixYa!
Mar 09, 2009 | Pioneer VSX-917V-K Receiver
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
Panasonic SA-HE200 Receiver Logo
327 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
