Question about Fuji FinePix S5000 Digital Camera
Zoom error Hi.. when I turn the camera on it says zoom error, and I can not take a picture.
  • mikonio Sep 26, 2008
    I have the same problems.
    My camera lens will not extend, at all.
    And all that it says on my display screen is "Zoom error."
    It's quite irritating.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Zoom Error
hi thanks for using fixya!
On this kind of error, I suggest that you bring your camera to a service center or to your retailer to further check the hardware problem of your camera.
Regards!
Apr 30, 2009 | Fuji FinePix A500 Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Zoom error
Sounds like you have a problem with the optics of the camera.
May 07, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
